Ovens Logo
Anita Zanotto Posted on Mar 31, 2014
Homedics Air Revitalizer, Model BRT 150 -Power switch doesn't work
Power switch won't work . Parts available/Service or instructions to replace part?????
MY JENN-AIR MODEL #WW2460B WALL OVEN DOES NOT DISPLAY THE CLOCK/TIMER. IT STOPPED WORKING DURING A SELF CLEAN CYCLE. IS THERE A WAY I CAN ORDER THE PART TO REPLACE IT MYSELF AND ARE THERE WIRING SKEMATICS...
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-WW2460B/1266/0125300?pathTaken=&prst=0&shdMod=WW2460B
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Gene
Most of the buttons on the panel do not respond when pressed. incl;uding, convection, setup, rapid preheat
Are the oven doors locked as well, check if the front panel lock is active. Press and hold both the upper oven Cancel and Cook & Hold buttons for 3 seconds (or a bit longer). (Off should disappear from the display and the Lock indicator will flash.)
If that doesn't help, try pressing Cancel. Then try pressng the Cancel and Cook&Hold keypads together. If this doesn't help, then the control panel or the control itself is damaged and probably needs to be replaced. (Touch pads like this have electrical contacts on a membrane that is impossible to fix long term by cleaning the unit.)
For a parts list and prices see: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-JJW9130DDS/1266/0125300/M0603043/00001?blt=06&prst=&shdMod= or http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170052&diagram_id=28429593 . Specifically part 1A and 2 are suspect. The control panel is the more likely part to fail (much like a membrane keyboard).
Most Jenn-Air appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . Fill in Consumer and then the model number and press the right arrow button. The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf .
I hope this helps.
2answers
Model : ACE 23300 S/N IMD 2676010 Type 24 Admiral ranger After someone turned around the timers, the oven part of the range stopped working. Cookotps still work. All the fuses are good, the lamp...
You will need to replace the oven temperature switch. I did not find any parts available for that unit to direct you to. Do you have anymore information on it?
Aug 03, 2011 • Ovens
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
When the electricity goes out the F7 button comes on and the manuel says to turn the power to the unit of and it still comes back on
Unfortunately the F7 error code normally means a problem in the controller or touchpad (replacing both is common and parts alone is about $300)
You might try shutting down the power. Then finding the ribbon cable connector for the touch panel, unplug and clean the edge connector with a #2 pencil eraser. Sometimes that improves the signal enough that it will work a little longer, sometimes it doesn't and then you are talking about a $300 parts expense plus your labor or the $300 parts and Service call and labor expenses if you call a service tech.
1helpful
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
3answers
Need a wiring diagram for a jenn-Air range. Oven element burned out and replacing it didn't fix the problem. Don't want to spend $150 for a thermostat if ther is something else in the circuit that could be...
Hi. It could be your thermostat not sending power to bake element. If elements are really burning out that fast, check the voltage coming to stove. If more than 220 volts, could be a problem with the power coming into your home. Check also the element if it has continuity.
Oct 21, 2010 • Ovens
2answers
I need to replace a switch(dual infinite switch) on my kitchenaid oven (YKERC607) but I don't know wich wires go where. Could someone help me? Thank you un advance. Mathieu
An instruction booklet should have come with the part, but if you didn't mark or label the wires when you took them off the old switch, then you have to identify them by whatever method is available. Appliance Dealer repair shops usually have microfich or computer schematics to identify parts and their assembly, and you might try to call on one of these places, if you can. They're usually more than happy to bring up the diagrams and try to assist. Other than that, one would need a full fledged service manual, and other than being difficult to find, they're usually somewhat expensive, but not always. Here is a great link to a site that has some good information about appliances, and they do have your parts, and may be of assistance to you since they also have instructions for the parts. They may be able to email you a scan of the instructions, never know till you try...so contact them. Here's the link:
http://www.repairclinic.com/Brands-We-Carry
Good luck, hope this helps, and thanks for using FixYa.
Aug 27, 2010 • Ovens
5helpful
2answers
Oven does not work,
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at http://appliancehelponline.com/ovenelementvideo.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
If the element checks good it probally blew the relay on the main control board you will know this if you have no power to the element.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
