Question about Delta Baby Gear
Enterprise 2007 delta bassinet style 532-01
  • 2 more comments
  • Joe  A
    Joe A Apr 01, 2014
    Hi Martin Smith, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Martin Smith
    Martin Smith Apr 01, 2014
    i have received this model from a friend in pieces, need assembly instructions on how to get it put back together, specifically how to assemble the bedding
  • Martin Smith
    i have tried it numerous diff ways, sure its something im just overlooking, but if you (or anyone) can provide a manual or pdf file i can download, would be great?
  • Joe  A
    Joe A Apr 02, 2014
    It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and you should be able to download a PDF version of the instructions from the maker. Just go to their site and search.
Instructions for alex convertible crib style 910
I could only find instructions for the Model 525. Maybe they can help. If not let me know and I will dig deeper. Model 525 Instructions Link
Jan 20, 2013 | Delta Luv Jasmine 4852 Crib
Was there a recall on the delta mod#4890-2
You will have to visit their site and inut the info. It will show you 2 styles. Finger pull dropside and
handsfree dropside. Follow the directions and if it is on recall they will send you a Free kit.
Use the link below.
Delta Recall Lookup
Apr 04, 2011 | Delta Luv Delta - Baby Products 5-in-1...
I enter in my model number 4322 and it says it is invalid. Just trying to fix the drop side according to the recall
Respond to this answer. I need to know if you have a FINGER PULL style dropside
or if you use your SHIN to push and drop the side down. I will get you the number you need.
Mar 06, 2011 | Delta Enterprise Capri 3-in-1 Crib
I would like to know if this crib model has a recall " model # 4624-1" date of Man. 03/24/06 Thank You
Here is a link to check using the date of manufacture and model and style.
They used a finger pull style and a shin push. Just follow the directions
and they will send you a free kit. It does appear there is a recall for it.
http://www.cribrecallcenter.com/recall.asp?pa=1
Mar 05, 2011 | Delta Luv Normandy Crib
Purchased the Jenny Lind style crib from a rummage sale, but it didn't include the bars that support the pressed wood bottom (the flat piece that the mattress sits on) I believe they are called stabilizer...
Wow, you are in a tight spot. Those will cost alot from Delta and they are rare on the used market.
You may get lucky if Delta has a recall for your crib, maybe, just maybe, they will send you them free.
If not hopefully they can sell you a set for a good price. Use the recall to your advantage if this is true.
Your posture board has the info you will need to ask them about.
Hours of Operation Monday through Friday
8 a.m. to 8 p.m. (Eastern Standard Time)
1-800-377-3777 extension 6221, or
212-645-9033
Mar 05, 2011 | Delta Luv Delta - Baby Products 5-in-1...
I cant find the rails to convert my crib into a bed.
Delta Childern's Products has a very similar product called the Canton Crib (discounted)
I understand Simplicity is out of business, but I would try Delta Childern's Products Customer Service (AT YOUR OWN RISK) :
Monday-Friday 9am-5pm EST.
(800) 377-3777 extension 6221, or call
(212) 645-9033
Fax: (212) 645-9032
FYI: Many cribs may look similar, however their construction and hardware systems are different. Serious injury or death can occur if the incorrect hardware is used on a crib. Please ensure you actually have a Delta crib. Our cribs use a mattress board and not a metal frame. Our name Delta Enterprise or Delta Children’s Products can be found on the instruction sheet that is glued on the mattress board.
Aug 13, 2009 | Simplicity for Children 4-in-1 Convertible...
Need instructions to Delta Jordan Crib Style # 4887-1
im trying to put together a delta jordan 5-1 crib i need to know where to start the instructions aren't clear enough
Aug 04, 2009 | Delta Enterprise Baby Gear
Baby Gear Logo
65 people viewed this question
Top Delta Baby Gear Experts
Paul Carew
William McDowell
Are you a Delta Baby Gear Expert? Answer questions, earn points and help others
