Question about Goodman Heating & Cooling
Replaced capacitor, outside unit coming on, but no air is coming out of the vents
Check blower motor has voltage to it thru your circuit board
Posted on Jun 15, 2009
3 Suggested Answers
  • 358 Answers
SOURCE: AC unit outside blowing out cold air, vents
If you have a heat pump probably there's a wrong connectionin the thermostat, but if is not a heat pump ,the compresor is not working or the unit leaked all the refrigerant.
Posted on Aug 30, 2009
Testimonial: "thank you, we have had a problem in the past with refrigerant leaking, was supposed to be fixed"
  • 2418 Answers
SOURCE: My outside unit is working,
You need to check the inside fan. Check the inside unit (where you change the filter), Open the panels and turn on the A/C Look for a panel switch located on the frame where you removed the panel and if there is a switch press it in. Listen for your fan to be turning, any scraping, scratching, means worn bearings, slow turning means bad relay, or capacitor. Hope this helps Fixya up.
Posted on Aug 13, 2011
I have a york 80 diamond heating and air conditioning unit. When it is turned on air comes out of the vents but it does not feel cool at all. When I check the unit outside it sounds like it is on but the...
Hello, if the compressor is running on the outside unit and the fan is not either you have a bad capacitor or a bad fan motor, if the fan starts with a push then your capacitor is bad, if it does not the motor is shot.
Jun 16, 2011 | Heating & Cooling
My outside a/c condensing unit's fan runs, but inside vent air is not cold. compresser may not be running. inside vent air was cold last week. Janitrol ckj361ab is model # of outside unit.
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Jun 17, 2010 | Heating & Cooling
Goodman cpl-j42-1a a/c unit, fan on outside unit not working, inside there is cool (not cold) coming out of vent..
sounds like you have a bad fan motor in outdoor unit or a bad run capacitor ck cap first you can go 1 size larger than listed on motor data plate
Jun 10, 2010 | Goodman CKL42AR42 Air Conditioner
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
My a/c not working
If the fan outside doesn't work ,the compressor will go off on overload .Try replacing the fan capacitor , if still won't turn . the fan motor has to be replaced.
Sep 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
AC unit runs inside but not outside! help
check breaker thermostat set cooling auto call for service.allso get it cleaned both coils.. Tom
Jun 19, 2009 | Ruud UAKA042 Air Conditioner
Ruud Problems
compressor is probably bad. disconnect it tape the wires off and start unit. if breaker doesnt trip it is the compressor.
Aug 17, 2008 | Ruud UAKA030 Air Conditioner
Air coming out of vents is not cold. Outside unit not running. 11 year old unit
Lots of possabilities. Could be fuses or circuit breakers. Could be tripped pressure safety switch inside unit. Could be failed run capacitor. Could be problem with a control board. Recommend having a qualified professional check the system out after you check breakers and fuses.
Jun 27, 2008 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
