Client id 004201679
Review my account
Cant log in my old facebook
If your account is under review, and you've uploaded your ID to Facebook, you'll have to wait until someone has reviewed your documents. If your Facebook account doesn't represent your real identity, as is apparent by the name you're using here, you probably won't regain access to it and it will be deleted.
Jun 08, 2017 | Facebook Computers & Internet
Tip
How to access your home PC files remotely
There are a couple of ways of doing this. Here are a couple of my favourites. All of these require you keep your computer on.
1. Opera Unite
If you install the freeware browser Opera, then create an account with them, you can start Opera Unite, an online service for accessing files and services from anywhere. After you have added the File Sharing application from the Unite sidebar, you can configure the application. Choose to add a share location and choose your main hard drive (generally C:). Then, change your password and make sure that you set your Opera Unite account to private and check that File Sharing is password-protected. Then simply navigate to the URL that Opera provides (generally username.operaunite.com), enter your username and password and then you'll have full access to your files. Note that you will need to keep Opera running on your Computer
2. FTP server. *Only recommended for advanced users
By running a FTP server software like FileZilla on your home computer, you can create a far more powerful file sharing experience. Now, first up, you should go to DynDNS.com, sign up for a free account and then create a Dynamic DNS host. Next, download and install the DynDNS Updater and run on your computer. Now, to access the files that you have configured with your FTP server software, simply use your DynDNS hostname that you created in the sign-in process into Windows Explorer or Internet Explorer (or any browser) with the ftp:// prefix instead of http://. However, if your computer is on a home network behind a router, you will need to configure that also. Set up a port forward (generally Port 20,21, and 23) to the computer running the FTP server. The other advantage to this is that by finding out the server's local IP address (open Run, then type cmd, then type ipconfig, and write down the IP address shown) you can also access the files from the server within your network, simplifying the file access process greatly.
3. Orb 2.0
This is one of the slickest and smoothest methods. Simply download and install the Orb desktop client from Orb.com (also create an account and enter your details into the Orb client), then add any folders you want to share. Then, allow some time for it to index your content. Now, from outside your network, log in to Orb.com with the account you created and click on the Applications button at the top of screen. If you want the music, videos, photos or documents you specified in the setup process, choose the appropriate application, or choose File Sharing to access all of your files at once. Simply navigate the folders as if it was your local computer and you will be able to use them flawlessly. You can even access other physical drives like your CD drive online.
4. TeamViewer
This is a brilliant VNC replacement application. Simply create an account, then install the client on your computer. Also, enter your account details into the client (click the button at the bottom right of screen) and write down your 12-digit ID and password. From here, you have several options remotely. I recommend that you should link up your account first. Navigate to login.teamviewer.com and login, then add a client using the ID and password from your computer. Now, whenever you login to your account, you wont have to remember your ID/password. You can install the client on another computer and connect with your account directly or login to teamviewer.com and use the Java-based applet to connect and use your computer as if you were in front of it.
These should work well when accessing your files.
on Apr 22, 2010 | Computers & Internet
Tip
Chat With Multiple Yahoo Accounts At The Same Time On Same Computer
Yahoo Messenger is today one of the most popular instant messengerservices. However, this service has its own set of limitations as well.Users using Yahoo Messenger must be aware that the service can be usedfor one account ID at a time. This means that if you want to usemultiple IDs for interacting with your clients and colleagues, you cando this alternately. You have to sign out from the current logged on IDand then log on to another ID. This is a big head ache for techniciansand professionals who need to activate their Yahoo IDs for servingmultiple purposes at the same time. But not any more! To serve the samepurpose, a revolutionary software M Multi Yahoo Messenger has beenlaunched.M Multi Yahoo Messenger is the software that allows users to loginto Yahoo Messenger with multiple Yahoo IDs at the same time. Thismeans that you can now work on more than one window of its instantmessenger client. With the help of this software you can easily loginwith different Yahoo accounts at the same time. This way you can easilyinteract with different groups of friends in your friend lists at thesame time.
This software is available for free of cost to all the online users.It does not require the installation of any other software or plug-into activate this software. It is compatible with all the versions ofYahoo Messenger. It appears as a patch on your IM client software.
on Jan 29, 2010 | Computers & Internet
Error code 800488fe
Open your Web browser. Navigate to the Windows Live account homepage (see Below). https://login.live.com/login.srf?wa=wsignin1.0&rpsnv=11&ct=1302976541&rver=6.1.6206.0&wp=SAPI&wreply=https:%2F%2Faccount.live.com%2F&lc=1033&id=38936 Click "cant access your account" under the login boxes. Type your Windows Live ID into the box. Type the letters and numbers displayed in the picture box. Click "Next." Click "Email me a reset link." Open your email client. Open the reset email sent to your account. Click the reset link. Type a new password to change your Windows Live password.
Jan 11, 2013 | Alpine Snow Hotmail & MSN Password...
TRYING TO SET UP A YMAIL EMAIL ACCNT. SAYING THERE WAS A PROBLEM?
The ID that you are trying to use is already taken by someone else, please choose a new ID and try again.
Nov 16, 2011 | Yahoo Mail
Yahoo logins don't seem to work, it keeps saying it's an invalid ID or password even though the info entered is correct. If I use the password helper it just keeps asking me to enter a security code.
T ry going to Yahoo's account password helper site: https://edit.yahoo.com/forgotroot
Follow the appropriate steps for your situation. This should solve most account related issues.
If this doesn't help, please post the client you're using (most likely Yahoo's client), the client version number, any error messages or relevant information and your version of Windows.
Please leave feedback if this was helpful. Thanks.
Dec 15, 2010 | Yahoo Mail
I want to retrieve mail from inbox(mailbox) with include search also by using pop3 protocol. my coding was work properly but after sometimes messages are deleted in server. please tell one solution...
Are you looking for a way to avoid messages to be deleted from server and see messages only from that mail ID in your inbox or how program to retrieve mails from that mail ID only. If the first, you can set the account settings of your mail client and specify not to delete messages and to keep a copy of messages on the server by using the Advanced tab of the account setting on your mail client such as outlook express.
Nov 26, 2010 | Computers & Internet
Cant access my account
roxy_girl1980@yahoo.com is my email address so can you help me
May 16, 2010 | Facebook Social Network
I wante make new account for itunes
To create an iTunes Store account using your MobileMe account or an existing Apple ID, follow these instructions:
  1. Open iTunes (If you do not have iTunes, you can download iTunes).
  2. Choose Store > Sign In.
  3. Enter your MobileMe account or Apple ID, then click the Sign In button.
  4. You will receive a message stating that the ID you have entered has not been used on the iTunes Store before, click the Review button.
  5. Read through the Terms & Conditions, check the box if you agree to the terms, then click Continue.
  6. Provide a valid payment method and billing address.
  7. Begin shopping from the iTunes Store.
Oct 18, 2009 | Apple iTunes
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
