Question about Nordic Track Commercial 2150
Decline goes up instead of down on quick buttons and pre-programmed runs
I purchased my treadmill in late December 2013 and I have had issues with it since day one. The quick change incline on the console is not accurate. I can be at an incline of 3, press 1, and it will go up to 5 rather than down the two levels it needs to in order to get to 1. In addition, the pre programmed videos are made to change the incline as the terrain changes; however, it will take it up to 3 if thats what the program is telling it to do but when the program tells it to go down, it just goes up however many levels it should have went down.
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 218 Answers
SOURCE: My treadmill lights come on when i push a button
the motor controller is bad
Posted on Aug 11, 2010
  • 218 Answers
SOURCE: My Nordictrack treadmill seems to
it is trying to calibrate itself, let it go the whole way up and then down without interrupting it. Then it should be fine.
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
SOURCE: incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Posted on Mar 07, 2011
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Lights up, start does not start on console, belt won't move , decline , incline does not work, age goes down but not up, speed does not work...pulse on handles work,,,
Do you have the iFit component on your treadmill? We had a similar issue and I unplugged the iFit component (requires opening the console and unplugging the ribbon cable that attaches the iFit component) and the treadmill started working again.
Jun 08, 2014 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordic track C2050 treadmill one day everything was working great the next day the only the #1 and #7 speed button worked decline up and down stopped working plus all program buttons not work
replace the old batteries ( if your system has batteries, clean the spring contacts from oxide, corrosion, etc with contacts cleaners) put a new batteries.
2) tight and clean the ribbon cables from display board
3) tight and clean the uppers and lower connector very well.
4) adjust the REED switch, tight the connector, clean it, and test the reed for open or faulty. see the diagram attached.
Oct 25, 2013 | Nordic Track Nordictrack C2050 Treadmill...
Continuous incline with no lights on display except 2 lines on the incline
RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
God bless you
Sep 04, 2012 | Icon Epic T60 Treadmill
Replacement console
Unplug unit then remove the upper console, their are 4 allen bolts holding it udder the console their is a panel held by 4 phillips head screws also remove them . Look inside the compartment and their should be two connections, disconnect them. Now pull console off its tower. Lay it upside down on a thick towel remove all phillip head screws you'll notice where the emergency stop button is connected. I have found that this connection 7 out of 10 times is causing the problem. Buy cutting the lead connector stripping the wires and soldering back on the male connection will resolve the problem. If not their is a emergency stop kit may be purchased and replace. The only other thing that may cause the problem is the function key pad itself. Try the first solution if your not good in soldiering go to a computer shop , t v shop they should be able to do this very quickly for while your at let the check the switch itself.
May 17, 2010 | Life Fitness 9500HR Treadmill
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
I need to know how to program my Vitamaster 1171 treadmill
First tell me what kind of treadmill is that you have, because generally the treadmill and have pre-set programs, the only thing you have to do is select the one you want to start and press the button "Start" and automatically you will run the exercise. if you see dips in the speed is so because they are designed mainly on the slopes tends to slow down even protect your heart rate
Feb 01, 2010 | Exercise & Fitness
My nordic track treadmill won't decline
My wife had the same problem with her treadmill. I turned the beast on it's side, and unscrewed the plastic casing that houses the motor, computer, and all the electronics to the treadmill. I unplugged the incline/decline motor. Then on the bottom of the treadmill the long threaded rod that causes the incline needed to be moved. So I unbolted it from the catch, and manually screwed the rod back in with a wrench. Now the treadmill works fantastically, of course the incline/decline mechanism has been disabled, but I would rather have a treadmill with the incline disabled than have one always on 100% incline. Hope you found this helpful :)
Jan 05, 2010 | NordicTrack Exercise & Fitness
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
Nordic Track Commercial 2150 Logo
102 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
