Question about Great Northern Popcorn Company Great Northern Paducah Popcorn Machine
Need wiring diagram or wiring colors to install replacement switch
Found replacement switch, but kids pulled the old one out before I got a picture of the set up. The switch has 3 connectors, and there are 3 sets of colored wires one to hook up to each part of the switch. Red, blue, and yellow? IF I remember correctly, I'll double check tonight and take a picture of it.
  • D.J. Yasui
    D.J. Yasui Mar 31, 2014
    Should note model: Great Northern Princeton 8oz popper
    Champion:
  • 252 Answers
Contact http://www.greatnorthernpopcorn.com/ For detailed information.
But, the color scheme should be the same for each switch. If you are replacing only 1 switch, you can copy the colors from the other switchs
Posted on Mar 05, 2015
Need a KTE 3A-250VAC ceiling fan pull switch wiring diagram for a 3 speed Harbor Breeze fan UL model HST52-II
They are all wired the same, just go for color for color when changing the switch. It can be a testing job to release the old wires and installing them into the new one. Not much room.
May 28, 2017 | Dryers
I have a 1988 olds 98 regency brougham and my backup lights not working I need help with checking the safety neutral switch which wires to check for power and counity
This is an old diagram I found, hope the wire colors are correct?The dark blue wire carries voltage to position switch for back up lamps. When in reverse the lite green wire carries voltage to back up lamps and the black wire is ground.
Nov 11, 2016 | 1988 Oldsmobile Ninety Eight
Have hampton bay add on remote control kit on patio ceiling fan. Battery died in the remote, so kid turned fan off with pull chain. replced battery, now cant get fan to work on any pull chain settings....
The pull switch in the fan may be broken in the off position. Luckily these are easy to replace. Purchase a new switch. Obtain a wire stripper and phillips screwdriver. Lower the light (if installed) or the blank by removing the screws. Disconnect light if installed. Unscrew nurled knob on fan switch and remove switch. Make note of where the wires go, I take a picture with my cell phone. Cut wires off as close to the old switch as you can. Strip about 1/4 to 3/8 inch of the insulation off the end with the wire stripper. Insert into the appropriate hole in the switch. Nothing to tighten to lock down here, it will hold it. Reinstall switch and light and test for proper operation.
Jul 09, 2011 | Garden
I have a set of hand controls for a 95-06 Harley with no diagram how Do I figure out witch wire from the switches go were
If you're simply replacing the controls with other controls, the color coding of the wires should be the same. Simply unplug the old wire from the plug and insert the same color wire from the new set. Now, if you're trying to install a later set of switches on an earlier model bike, you need a wiring diagram of BOTH the new switches and the old bike so you can figure out the color codes on the wires.
Good Luck
Steve
Mar 02, 2011 | Harley Davidson XL 1200 C Sportster Custom...
I wana put 04 harley hand controls on a 89 harley need wiring diagram
I think the wire colors changed sometime after 2000. If you still have the old controls, you may can make up your own wiring diagram. While you've got the switch housings open to put them on the handlebars, write down what color wires come off of what switch. Do the same with your old switches and your new switchs. If your horn button uses a red and a black wire on your old controls, and your new switch uses a red/white and black wire, then draw your diagram to match the red/white wire where the red wire went.
You're going to have to do a certain amount of this as you will not find a wiring diagram that shows an 89 model bike with 2004 handle bar wiring on it. Good Luck!
Jan 26, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Wiring diagram Ignition switch
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 19, 2009 | 1984 Mercedes-Benz Mercedes Benz 300 Class
Im looking for a electric diagram so i can hook up my new fuse block i dont know where my color wires go to on my new fuse block i need a picture or diagram showing me the color and where it hooks up to
pull the old fuse panel away from the bracket and replace them one at a time in the same position to the new one as the old...
make sure the battery is unhooked as well.
Robert
Sep 08, 2008 | 1992 Ford Ranger
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Replace old tv antenna with a new one.
make diagram on paper of the old socket . Carefully unscrewing old socket from wall, DO NOT CUT WIRES, copy color of wires (if any) and where and how meny wires on the paper. EXAMPLE:: you have just pulled old socket away from wall, look and see how meny wires, colors if any, and where they are in contrast to the socket.(left wire=blue, middle wire=black, left=yellow, connector that is up or down=color. MARK these wires on paper, and if possible TAPE a piece of paper with a nember[#] on the wire and place that # on the paper corresponding to the wire in socket wall.
Take the socket to electronics store.NOTE;; IF STORE does not have a exact replacement ask store for SIMULOR replacement.Show the diagram you made to help you buy the right replacement.
Good luck
May 05, 2008 | Televison & Video
Great Northern Popcorn Company Great Northern Paducah Popcorn Machine Logo
237 people viewed this question
Top Great Northern Popcorn Company Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Great Northern Popcorn Company Kitchen Appliances - Other Expert? Answer questions, earn points and help others
