Question about Raggedy Ann Costume Yarn Babies Ragamuffin Dolly Sz 2-4
Knot tying instructions/yarn
Granny squares with many colored yarns all need to be tied off but don't want them to come undone
  • 39 Answers
Tie the knot with a reef knot then thread any spare yarn through the side of your squares.
Posted on Jun 12, 2014
Why is my crochet border on my granny square blanket going wavy. I a man using same wool and crochet needle
There is something off with the gauge. The stitches are too large, the needle is too large, the yarn is to heavy,
Aug 07, 2017 | Sewing Machines
I am making half throw in the cable pattern also 2 cushions in aran wool how much wool would i need to buy
You deleted the last post as I was just about to post the answer!!
a set of aran knit cushion covers knitting pattern 99p ' to Knit ' Pinterest ...
https://www.pinterest.com/pin/353040058269560085/ Vintage Aran cushion cover set knitting pattern by knitcheap, £0.99 ... CUSHION FROM SQUARES - 250 grams of ARAN in Crafts, Knitting, Patterns ' eBay ... The possibilities for using sweaters for pillows are endless.... and would make great gifts! .... Many owl patterns on Ravelry, but don't have the seed stitch in the "body" ...
Double bed sized knitted throw - Knitting Paradise
www.knittingparadise.com/t-215627-1.html
  1. Cached
  2. Similar
I want to knit my nephew a double bed sized throw how many balls of double knitting wool 100grm balls of wool will I need please. ... im currently crocheting a large granny square bed over and currently am on ball 5 of 1000g aran wool just to ...
Knitting Calculator - LoveKnitting
www.loveknitting.com/knitting-calculators
  1. Cached
  2. Similar
The world's largest range of knitting yarn, patterns, needles, books and ... Circular · Single Point · Double Point · Interchangeable · Sets · For Children · Cable Needles · Crochet Hooks ... Convert between grams and ounces ... Roughly how much yarn will I need for a particular garment? ... Worsted, Aran, 10 ply, 4.5- 5.5 mm.
Estimating How Much Yarn to Buy - dummies
www.dummies.com/crafts/crocheting/estimating-how-much-yarn-to-buy/
  1. Cached
You need to know how much yarn to buy whenever you start a new knitting or crocheting project. You can figure out the yardage by using yarn calculations, ...
HOW MANY GRAMMS OF ARAN WOOL WOULD NEED TO KNIT TWO CUSHION COVERS Google...
Dec 27, 2016 | Sewing Machines
Can I use dryer balls and/or dryer sheets in the kenmore steam dryer?
Instructions
Things You'll Need:
* Wool yarn
* Scissors
* Crochet hook
* Pantyhose or sock
Make the Core Ball
1.
Wrap some of the yarn around your fingers.
2. Take your fingers out of the loop you created and close the hole by pulling the yarn through it.
3. Wind yarn around the loop until you form a ball about 2 inches in circumference.
4. Cut the yarn attached to the ball using the scissors. Try to leave a little excess yarn dangling from the ball.
5. Grab the excess piece of yarn with the crochet hook and tuck it inside the ball to prevent the ball from unravelling during the felting process.
Primary Felting
6. Put the core ball into the pantyhose or sock, and tie the open end in a knot. (If you are felting more than one core ball at a time, you can separate them within the pantyhose or sock by twisting the fabric in between the balls before tying the knot.)
7. Put the pantyhose or sock containing the core ball into the washing machine with a load of laundry.
8. Remove the ball from the pantyhose or sock when the cycle is complete. It should now be slightly felted. To increase felting, simply repeat this process.
Enlarge the Ball
9. Wrap more yarn around the felted core ball to increase its size. It's all right if you make the dryer ball a little big at first, since it will shrink over time as you use it. A good initial size to make a dryer ball is around 9 inches in circumference.
10. Cut the yarn with the scissors once you have made the ball the appropriate size. Try to leave a little excess yarn dangling from the ball.
11. Tuck the excess yarn inside the ball with the crochet hook. This will prevent it from unravelling when in use.
Secondary Felting
12. Put the dryer ball into the pantyhose or sock, and tie the open end in a knot.
13.Put the pantyhose or sock into the washing machine with a load of laundry.
14. Remove the ball from the pantyhose or sock when the cycle is complete. The dryer ball should now be felted and ready for use the next time you do laundry.
Feb 28, 2011 | Kenmore Dryers
I'm feeling really stupid but I can't seem to feed the wool through the yarn feeder. I'm trying to do a practise piece of work on a Singer 326 knitting machine which I have just aquired.Help! Lyn
right now then just check you are not using too thicker yarn.. and that you have not got the tension disk too tight it may help you to loosen them off completely so you can then thread it through then tighten them to the required tension, also once you manage to thead it up never take the yarn out break it bear to the floor and tie a little knot with ends clipped close and just pull the new colour through it a good cheat! You should firstly lay the yarn in the place in needs to go between the two disks then pull down a little but more to the side it should be to the side away from the centre of the bed on which ever mast your threading up.. it should click and then run freely, hope this helps...Heidi
Oct 15, 2009 | Singer Deluxe Knitting Machine
How to tie knot using handy stitch machine how to tie off the thread so it won't come undone.
When you get to the end cut the threads long enough to be able to tie.
From the wrong side of the fabric, if you pull the thread slightly you will see the a loop from the top thread, pull this, so now both threads are on the wrong side, tie a square knot and cut close to knot, you can also put a drop of fabric glue on the knot to help secure it.
Hope this helps, and please rate if helpful or not
Moni
Sep 20, 2009 | As Seen On TV Handy Stitch Mechanical...
The drive belt on my kitchen pro breadmachine has broken. Its a toothed belt and I have not got the model #
Is it a Regal Kitchen Pro? If so, it should say so on the housing of the machine.
Follow the instructions on how to measure for a belt below. I used yarn because it gives a little, and just using a measuring tape would not give as precise a measurement.
Remove the safety cover from the bottom of the machine, exposing the wheel and drive shaft (it's easy, that's all you will see, those two parts) and run yarn around them, pull it snug, knot it, cut the yarn, remove the yarn, stretch the yarn a little on a measuring tape or yardstick, that is the length belt you need. If your machine is a k6725 it will measure 23 and a half inches. Proceed as below.
If the measurement is different, you have a different model, maybe. Google the measurement you get and the words bread machine belt, and see what you can find. Good Luck, read below how I fixed my Regal machine, which I got for free, with an Oster belt, for $14.90.
My Regal Kitchen Pro 6725 Breadmaker belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
Patti Wilson
September 2009
Sep 13, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Need a belt for K6725 breadmaker bjc
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
Patti Wilson
September 2009
Aug 04, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Belt for Regal 6725 bread maker
Patti Wilson
Mar 23, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Raggedy Ann Costume Yarn Babies Ragamuffin Dolly Sz 2-4 Logo
193 people viewed this question
Top Raggedy Clothing Accessories Experts
Da Doc
ray gallant
Are you a Raggedy Clothing Accessory Expert? Answer questions, earn points and help others
