Question about Biostar Bios Chip:Ta790gx 128m Ta790gx M2
HANGING on bootup!!
Sorry. my board is a TA-790GXB A2+ not a TA-790gx m2+ as I referred to above. and my board is hanging on boot-up every time. New SSD hard drives, legal copies of windows just flashed the bios, cleared the cmos, everything you can think of. Help!!
iqbal_del
  • 652 Answers
SOURCE: Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Posted on Apr 23, 2008
map9966
  • 2351 Answers
SOURCE: I recently tried to install a new WD320Gb HD and
You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Posted on Apr 26, 2009
SOURCE: Can't seem to flash the BIOS
My english is not perfevtly. I had this same problem. I use Uniflash, russian program to flash bios. It's working. http://www.rom.by/book/Uniflash
Posted on Jun 14, 2009
SOURCE: P4VMA-M motherboard won't recognize SATA hard drive
http://img.photobucket.com/albums/v242/Saphirex/wdsata2.jpg
http://img.photobucket.com/albums/v242/Saphirex/wdsata22.jpg
Posted on Jan 12, 2010
  • 3 Answers
SOURCE: i recently purchased a new mobo (biostar
I Need a Answer For The Biostar -
MCP6P M2+
AMD2 board
I am useing a 430 Watt power supply
now that the onboard video from the back of the computer has broken/revoved
was removed for fire hazard risks/ was not repairable soldered broke loose from the board it was attached to made by biostar INC
I went out and bought a brand new ATi Diamond Multimedia Radeon HD 6450 pci express 512MB GDDR2
pci express card
my problem is my video is not coming up/ no post
now I did read there pdf material for my board on bio setting enabing features etc but thats only if you had the onboard video to get there first hahah
right come on lol
can you help me out here if theres a solutio
my only sollution thought of mind o knowledge where to go is
I can go buy a new board same 100 % at electronic pc store they have it take this video card back come back bio-settings with new board then return it buy the video card again then procide?? would you suggest that?????
Posted on May 28, 2010
I bought New GeForce FX 5500 256MB Graphic card,After inserting it in slot. It is getting hanged in the startup of Windows, or some time it is getting hanged at bootup up. not even able to go into safe...
Does your motherboard have an internal video card? if it does, go to system bios and turn it off. it might be a conflict between the internal video card and your AGP card. Lastly, have you uninstall the old video card driver software? before installing your AGP video card. there's a possibility that there's a video driver conflict. If it still doesn't work, it might be a hardware conflict,compatibility or failure.
Good luck,
Ryan
May 24, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
System boot hangs at "Hard drive activation
This system refers to a sensor in the drive that is meant to alert the system of possilbe platter damage.
I would take this to a professional to see if they can recover data of the drive for you.
The drive is damaged if the system is hanging during the check and most likely cannot be recovered. All you can do is buy a new drive and take it all to a data recovery specialist.
Mar 23, 2011 | IBM ThinkPad T43 Notebook
Acer 7549-1284 shows acer symbol then goes to a black screen, it won't bootup
Well to start u need to go into the bios and shut off the acer splash screen. Then u can see where its hanging up at while its trying to boot.
Aug 16, 2010 | Acer Aspire 7520-5185 Laptop
Pc hanging
Scan your PC with a good antivirus like avast which support boot scan;it will solve your problem if it is caused virus,worm or malware.
Sometimes system hangs when a porgram start to load during bootup too.
for troubleshooting this,boot your system in sfae mode during startup by pressing F8.Click "start" then "Run" type "msconfig" select "startup" tab untick all the program and restart your system.
PC hangs or reboots due to overheating of the CPU.It is caused by dust and dirt contamination inside.open the system and blow it with a small air blower.
Dec 18, 2009 | Acer Aspire One PC Notebook
There is lot of hanging problum in my G502 phone plz help me out...... it hangs all the times
To overcome the problem, update your software.
Download and install Sony Ericsson Update Service.
Run Update Service and follow the instructions to update your phone.
Note: You must be online to update. You will lose all your data. Backup before updating
Nov 22, 2009 | Sony Ericsson G502 Cellular Phone
Window instolation bootig files for hanging
Refix your RAM also check your hardisk is properly detected in bios .
Load optimal defaults settings in bios.
Aslo try with other bootable disk some times disk corruptation create this problem.
Jul 23, 2009 | Intel Motherboard
Kept on hanging up
jha - you could be having a problem with the memory card, you could try a new m2 card and see if it hangs if it does not it was the card but if it still hangs with a new card then you should try and reflash the firmware on the phone.....to fix it...you can do this online at topsony.com or at a mobile service center.
Guest - reflash the firmware on the phone
Jan 27, 2009 | Sony Ericsson W910i Cellular Phone
The mother donot boot up if the cpu in its maximum speed
Computer hanging means it is unstable try 2.2 ghz instead and use a benchmark program off net to test system
Jan 18, 2009 | ASUS P4XP-X Motherboard
Bootup
Ed,
Are you referring to the white underscore in the upper left corner of the monitor on bootup? It is very likely that a device driver is hanging on boot up.
To find out which one:
1. Upon restart, press F8 (several times) to force the Windows startup menu to load.
2. When the menu loads, select the option that allows you to manually confirm or deny the loading of each device driver.
3. When you have discovered which driver is not loading, perform another reboot, and do the step by step confirmation again, and say NO to that driver.
4. Finish loading windows, and correct the issue with the offending driver.
5. Reboot yet again, and allow windows to load normally.
Nov 03, 2008 | Audiovox Jensen NVX-3000PC 7 Windows XP...
System Hanging at any time
Dear Ramesh,
Have you ever change/update your RAM in recent time?
Mar 14, 2008 | Intel D845GVSR Motherboard
Biostar Bios Chip:Ta790gx 128m Ta790gx M2 Logo
27 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
