Question about Sony VPL-CS7 Multimedia Projector
When I turn my projector on within seconds it turns itself off.
    Novelist:
  • 85 Answers
Are the fans all starting up? The symptom you describe is often associated with a faulty fan. Also could be a failed lamp, as the projector will shut down if the lamp does not strike within a defined time, although in this case the 'lamp' light should come on
Posted on Apr 09, 2014
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
BENQ MP620C: We changed the bulb when old one was in 4000hours, but cannot reset the lamp timer? How to do this, because the projector turns itself off very quickly (we have maybe 30sec. time to...
I also had this problem but was able to get to the menu before it turned itself off..... Instructions in the manuel on how to reset the timer.
15. Resetting the lamp counter
Do not reset if the lamp is not replaced as this could cause
damage.
i. Press and hold the Exit 5 button on the
projector for 5 seconds to display the total used
lamp time.
ii. Press Auto on the projector or on the remote
control to reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
Jan 01, 2011 | BenQ MP620 Multimedia Projector
How do you reset the Projector after installing a new lamp?
There are two common methods to reset the lamp counter on these projectors: Method 1: - Press the decrease volume button on the remote and then the increase volume button within 3 seconds. - The LED light on the projector will turn green. - Turn on the projector. Method 2: - Turn on the Projector. - Open the standard menu using the remote. - Then select "Setup" or "Service" depending on your projector model. - Then select "Reset Lamp Timer" hope this solution has been helpful?
Jul 19, 2010 | Sharp Projector lamp Projector Lamp
Turn on and it turns off by itself within a second
try to charge it maybe its low battery
Mar 07, 2010 | Nintendo DS Lite
What causes my dell 4100mp projector to turn itself off after only being on a few seconds?
lamp may not be seated right, or cooling system (fan) may be dead.
the projector will then protect itself from overheating.
Dec 03, 2009 | Dell Office Equipment & Supplies
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Hi Warson
If the Projector is switched on hold down the Enter button on the Projector itself for about 5 seconds - a on-screen display will appear that reads : " Keylock off "
This can also be done while the Projector is in standby mode by holding down the Enter & Standby/On buttons simultaneously for 5 seconds.
This should do the trick.
Good luck and thanks for using Fixya !
Apr 29, 2008 | Sharp XR-10X Multimedia Projector
Sony VPL-CS7 Multimedia Projector Logo
284 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
