Question about HP Office Equipment & Supplies
Remanufactured Ink Cartridges
My HPDeskjet F4440 suddenly stopped printing when using a remanufactured ink cartridge. Replaced cartridge with HP cartridge and printer works fine. Did HP upgrade printer program so that printer would not operate using a reman cartridge? Bummer!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • HP Expert
  • 146 Answers
Allways use original cartidges. Remanufactured inks may damage your printer.
Posted on Apr 13, 2014
2 Suggested Answers
vinodgill07
  • 30 Answers
SOURCE: REPLACED HP REMANUFACTURED 901 BLACK CARTRIDGE
your unused cartridges has been dried, so these should be replace with newer one.
Posted on Aug 22, 2009
Ink empty after replacing ink cartridge
Printers often show 'ink empty' when a remanufactured cartridge is used. Usually the printer will still print but some makes have a block that stops this.
My Canon does the same but i ignore the message and it prints OK.
May 22, 2013 | Canon PIXMA Office Equipment & Supplies
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp 5550 print cartridge light flashing.power light on,not flashin
All HP ink cartridges are dated. If you are using the remanufactured ones the date is not changed and will not work properly at all. By HP ink only and you will never run into this again.
Sep 03, 2009 | HP DeskJet 5550 InkJet Printer
Hp 5150 deskjet says that it is low on color ink
The low ink warning is actually normal for remanufactured cartridges. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. The prints should still be the same quality. You can either press the "Resume" or "OK" button to continue printing, or go into your printer settings and manually disable the ink level indiactor.
Feb 07, 2009 | HP DeskJet 5150 InkJet Printer
Change all ink message
Your Lexmark cartridges may be like my HP ones--they have a chip that the machine reads so they cannot be reused without doing some tricks to fool the printer.
My HP remembers the last 2 or 3 cartridges and also will not use ones that have passed the expiration date that is stamped on the cartridge. I'll tell you what worked for my HP.
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 25, 2007 | Lexmark X63 InkJet Printer
Printing problems
Are you using remanufactured cartridges? If so, I would strongly recommend that you replace with factory HP cartridges.
Apr 17, 2007 | HP DeskJet 920c InkJet Printer
76 people viewed this question
Seeker5211
Seeker5211
