Question about Health & Beauty
150cc scooter sputters while accelerating. the scooter jerks while changing mph's.
  • 22 Answers
SOURCE: 2002 Lincoln Ls sputters at about 40-50 MPH
first thing is the engine light on?
these cars had problems with the on plug ign coils and if this is a misfire the comp will tell you which cyl is the problem.
Posted on Nov 30, 2008
emissionwiz
  • 76132 Answers
SOURCE: Car sputtering and cutting off
has the fuel filter been changed? this sounds like low fuel pressure due to a partially clogged filter or defective fuel pump..
Posted on Mar 26, 2009
cadman000
  • 607 Answers
SOURCE: car jerking at 45 mph
sounds like you might have a misfiring spark plug or faulty wire
Posted on Apr 05, 2009
SOURCE: Car stutters at startup
My car did the same thing and I went and had it checked out. They had to replace my mass air flow censor. Cost me a little over $200. The only thing is after I had it fixed, my check engine light kept coming on. They said that my fuel line was running rich because I had ran my car so long with that problem. May want to get that checked out!
Posted on Jun 25, 2009
Benimur
  • 6966 Answers
SOURCE: 150CC Roketa Scooter
Hi and welcome to FixYa,
On most versions of Roketa 150cc engines, the choke is automatic and electrically driven..  It is integrated with the carburetor.
Good luck and thank you for asking FixYa.
Posted on Jun 29, 2009
Scooty kristal oil drain
Hi, David for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Oil Change Guide 50 150cc Chinese GY6
Chinese Scooter Oil Change Scooter Focus All about Scooters
150cc GY6 oil change
Free Bajaj Motorcycle Service Manuals for download
May 26, 2016 | Motorcycles
2008 150cc Znen scooter. What causes it to bog down at 55-60 mph?
Hi, Ty and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in the fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Headlights melting Engine bogging down
Yahoo Groups
SportiqueScooters com Scooter Buyers Primer http://www.carlsalter.com/pdfs/Znen_ZN250T_D.pdf
Gy6 50cc 150cc Scooter Repair service Manual Download Manuals Technical
Mar 06, 2016 | Znen Motorcycles
1986 f150 4x4 5.0 manual runs and ides fine but when you accelerate and shift gears it jerks and sputters
I am curious to know what the scan told you when you originally checked it? A lot of people spend way more money than they should changing parts and guessing at the fix. Tell me a little more about the what the scan results.
Dec 09, 2013 | Ford Cars & Trucks
On my 150cc milano moped theres a green wire hooked up to the black wire the black wire hooks to my battery a ground wire the green wire is smoking when i try to start it and it gets hot would it cause my...
Hi, David wires getting hot are usually caused by being worn or chaffed coming in contact with a ground which leads me to my next suspect a poor battery connection with the ground cable either at the battery or where it goes to ie. engine or frame.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
Scooter Troubleshooting Scooter won start All about Scooters
TNG 150cc Owner Manual
http://absolutelyscooters.net/service-manuals.html
May 21, 2017 | Motorcycles
When i compare my scooter with a 150cc scooter i found out that my acceleration is not good but only in the start any ideas?
Your scooter has a smaller engine than the 150cc scooter perhaps?
Seriously, without proper details, how can anyone help with this?
Dec 29, 2012 | 2006 Yamaha Majesty 400
Jun 24, 2009 | 2000 Nissan Maxima
Car jerking at 45 mph
Apr 05, 2009 | 1995 Chevrolet Lumina
Mar 26, 2009 | 2003 Buick Century
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
