Question about Nokia 6790 Surge Cell Phone
Internet says i have no connection
When I try to access internet it says status connection no data
  • 400 Answers
If the phone works okay otherwise, I suggest you go into settings and see if mobile networks is turned on. Mine has WiFi, as well as mobile networks. I hope this helps you find your problem
Posted on Mar 31, 2014
I have a 5 month old HTC Wildfire. I don't have access to WiFi and most often use Vodafone Mobile Connect to connect to the Internet. Suddenly, since the day before yesterday, whenever I'm trying...
Seems like your phone is functioning correctly.
You have disabled wi-fi so it is asking whether you wish to use Phone Data Connection instead. (Standard Practice when trying to access data services)
What you need to do is un-tick the option in options Use only 2g networks. (3g is the mobile data service) That should then allow you to access Mobile Data. (3g)
Also enable data enabled
Jun 17, 2011 | Cell Phones
Am not ableto access the internet,when i try it say connection failed
Check if you have a permission to access to the internet.. Check also if your internet connection is good, sometimes internet connections goes Offline status..
Try to reboot your router (if any), or restart your connection (disconnect then connect again)..
I hope this will help you..
May 21, 2011 | Computers & Internet
My modem ADSL data light keeps flashing and sometimes does not appear affecting my ability to acces the Internet. I usually have to re-boot my computer and this seems to solve the problem for a time. It is...
I usually have to re-boot my computer and this seems to solve the problem for a time. It is very inconsistant and anoying.Thank youM. Davis
ADSL DATA light flashes says there is internet activity (Internet status: Connected)...
ADSL DATA when off says there is no internet activity (Internet status: Not Connected)...
This occurs when there is a lot of noise in your telephone line...
It is adviced to do a line test in this case to find the amount of noise in your line...
If there is a lot of noise your modem will lose the internet connectivity and will try to re-establish the connection with ISP...
In this case the ADSL DATA light switches between OFF and ON...
One more thing...
ADSL SYNC light should be steady...
If it is blinking is says there is no syncronisation between your modem and ISP...
Dec 08, 2010 | Belkin Computers & Internet
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Not able to connect to internet
1. try to check the status of the connection:
make sure it is connected and the status does not say either of the ff:
a. local only
b. limited or no connectivity
c. limited access only
2. try to change the network name [ssid] and the network key [wep or wpa passphrase]
you can change this by accessing the ipaddress of the router or its user interface
3.try to reconnect to the new network name
and make sure the status says connected.
this is not a browser issue . it is with the connection set up.
Aug 05, 2008 | Microsoft Broadband Networking MN-500...
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Problem in internet connection
check fire wall setting if u have a back up for ur security soft remove it from the computer and try disabling all startup items
then check
May 19, 2008 | Compaq Presario M2000 Notebook
Nokia 6790 Surge Cell Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
