Question about Kodak Esp 1.2 All-In-One Printer
Kodak crash error codes for ESP1.2
Code2507
    New Friend:
    Problem Solver:
  • 11 Answers
Go to Kodak support web sit
Posted on Apr 06, 2014
Error code 3825
Answer: Answer last updated:11-17-08 Error code resolutions are updated on a regular basis. If, after you search, you cannot find a resolution to your error, the instructions below can help you.
IMPORTANT: Print this page before continuing.
Search for a resolution to your specific error code:
  1. Go to KODAK EASYSHARE Software Support.
  2. In the box under Find Answers, type the complete error code (without spaces), then click Search. An example is 12x413x1304x
If you don't find information for your specific error, follow the instructions below:
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
Nov 03, 2010 | Office Equipment & Supplies
Tip
Kodak Install issues Crash error codes uninstall
There are a couple things you can do to repair the Microsoft Installer so that the Kodak Software can get propperly Installed or Uninstalled. Try these few things the try to Install the Software again.
open the run window (start menu, run or press the windows key and the R key together)
type in
msiexec /unreg
press enter
open the run window again and type in
msiexec /regserver.
regsvr32 vbscript.dll
Then google or yahoo search for the Kodak Clear utility. download it and run it.
Now restart the installer.
Good luck. I will be adding more tips as i discover more issues!
SDtester
on Oct 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer kodak 5300 says error code 6203
printer needs to be replaced
call kodak at 18004216699
Feb 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Software crashes in Mac OS 10.6
EasyShare software may no longer be activated. Since Kodak declared bankruptcy, they have taken the the activation server off line. You will need to find another image editing software package.
Sorry about the bad news,
Bax
Sep 26, 2009 | Kodak Computers & Internet
Error code: 1-2036
go to Kodak easyshare support:
http://www.kodak.com/global/en/service/products/ekn026079.jhtml?CID=go&idhbx=easyshareswsupport
In the box under Find Answers, type the complete error code (without spaces), then click Search. An error code should be like 12x413x1304x
Cheers
Jun 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cannot communicate with printer error
error codes that you mentioned are not related to your issue you will get those are for front access door open and main paper tray empty.........the number of times you open the front access door and when ever the main paper tray is empty you will get that error.......you mentioned that HP printer worked......i would recommend to use a clear utility for HP and remove all the drivers and software for HP first as that might be conflicting with Kodak and make sure the version of the software for the home center(which includes drivers) is latest which is 3.4.......you can check for the version of the software by opening the home center and click on the question mark on the top right and then click on i which is on the right in the new pane that comes up and you will be able to see the software version in the right hand bottom corner on the small window that comes up.......if you have the latest version of the software then make sure you have the latest chipset drivers on your computer......for that you can contact your system manufacturer.......i suppose you have Dell...........if that also does not help then just tell me what all options you have under the Universal Serial Bus Controller.........also make sure if you have printer icon in the printers and faxes in case of XP and under printers in case its Vista.......if not then try and add a printer icon........if you already have a printer icon then try and right click on it and set it as default printer and then check if it works............let me know whats the result and was this helpful or not..............
Feb 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
New printer Kodak ESP 5 Error code 3821
ok i guess i need more information regarding the error code you are recieveing .... exactly what are you trying to do that prompts this error code to pop up ?
Aug 19, 2008 | Kodak Office Equipment & Supplies
Kodak Easyshare 5300, fatal error 3812
That's an error with the ink. Try updating the firmware on the printer. Here is the link to the latest firmware from the Kodak website.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
Dec 25, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak Esp 1.2 All-In-One Printer Logo
49 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
