Question about Sony Audio Players & Recorders
I have a sonyTA-AX-205 and don't know what cables I need to hook it up
Sony TA-AX-205
    Champion:
  • 287 Answers
Google search owners manual. download a copy and refer to the charts.
Posted on Aug 08, 2016
4 Suggested Answers
  • 31 Answers
SOURCE: need to find wiring diagram for a sony TA-AX 295 home amplifyer/eq
Hi *****, Try these URL's good Luck. YUBEUT http://www.eserviceinfo.com/ www.hisierrahifi.com
Posted on Dec 11, 2007
wiznet2000
  • 86 Answers
SOURCE: Sony ta ax 301 has ribbon wire connection from
Try to locate a mark on each board, see if it has a
dot or # 1 mark. start from that point up to the other end. (it's usaully a straight line pins)
Posted on Jun 22, 2009
  • 1212 Answers
SOURCE: need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
If you are trying to connect a ribbon cable tuner to a conventional RCA input terminal amplifier, it won't work because the ribbon cable carries the signal output as well as the data for frequency synthesis which is determined by the processor located in the amplifier ( that is supposed to work with that type of tuner), and the data buss for the buttons on the front of the tuner.
For the time and effort to put into a workaround, it is cheaper by far to get a tuner that will work with your amp. If cosmetics are not an issue, brand of tuner will not matter as their outputs are "Line Level" or nominally 1 volt peak to peak..
Posted on Oct 28, 2012
Can a 32in vizio tv be connected to an outside antena
Janice, yes you can hook up antenna. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cdn.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf
How to Hook Up TV Antenna
can watch tv on vizio without cable or dtv box
How to Connect an Antenna or Cable to Your HDTV For Dummies
Aug 04, 2016 | Vizio VW32L 32 in. LCD HDTV
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
Need connecting wiring for sony am/fm jx 285 connecting to the sony stereo amp ta-ax 285
Oct 27, 2012 | Sony TA-FE370 2-Channel Amplifier
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
Installation of sony ta-ve 170 wiring diagram
Hi, l have Sonyta-ve 170 in good condition,sub wofar connected but the four litter speakers ( center, front right & left,etc.
These speakers have only numbers at the back and there is no indications to say this is for that.
Can you please help me with the conditions so i mess up. thanks
Sep 22, 2010 | Audio Players & Recorders
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
May 07, 2010 | Yamaha AX-596 Amplifier
Sony ta ax 301 has ribbon wire connection from amp to cassette and tuner. The cable was lost when I moved need to know how to make a new cable I have all ready found wire ends but do not know which wire...
Jun 22, 2009 | Audio Players & Recorders
PS3 wont turn on!!!!!!!!!
happnd ta me 2 fan waz broken i had ta fukn buy a nu 1....sory mate , ax the shop where ya boht or else try ta buy a nu wun....
Oct 29, 2007 | Sony Playstation 3 (PS3) Console
197 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
