Question about Konica Minolta Bizhub C550
C550 P-9 Machine Status
Trouble with black print
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Replace black drum unit.
Posted on Nov 14, 2014
Only black white
Thanks for questioning, pl don't post shot cut questions,your inputs are more valuable for us to give straight away trouble shooting..>Check all cartridges are fully loaded?>Before any body attempted for trouble shoot?>Are you checked for supply status?> Are you performed color calibration?**** Do color calibration (go to menu,system set up,quality,color calibration,calibrate now)Take supply status print out(go to menu,scroll to reports,scroll to supply status, enter in to for print)check all colors are printed are not? If printer take print out from system or print demo page from printer menu.. check print quality...and color calibration..****Remove supplies.. observe while closing the door right side in the supply bank supply contacts engaging or not.(while closing the front door the 'bios voltage contact leavers' engages with the cartridge contacts for passing the voltage in to the cartridge for charging,see the attached snap shot)if these are broken,no contacts or not properly driving by the mechanism, results no print.. check for these contacts...*** alignment disturbed, its major issue users cannot perform this activity..submit in service center for this major issue.
Jan 08, 2012 | HP Color LaserJet 2600n Printer
What does Print unable 71 mean and what do I have to do to correct the problem?
Error code 71
Print Unable 71
Turn the power off and then back on again.
Polygon motor failure
Jan 03, 2011 | Brother MFC-9840CDW Laser Printer
My machine will not start. Under "Status" the red
Try pressing and holding the End of Cycle button for several seconds (3 seconds is usually needed but it may take 30 seconds). Otherwise try pressing and holding the Cancel button for a similar length of time. Usually there is very small print below the key indicating the Control Lock and the length of time needed to unlock it.
I hope this helps.
(I don't have your model. However, the above have worked for other Whirlpool front loading washers that I have used in the past. The CL is a child lock to avoid a small human starting a cycle by accident. Unfortunately the label is in such fine print that most adults have trouble reading it.)
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replaced black cartridge when machine indicated, but after two different cartridges ,it still shows replace black. What do I need to do?
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Color LaserJet 2600n Printer
How do I print the fax numbers I have saved in my M24
  1. Press the [Machine Status] button on the Control Panel. The Machine Status button is the bottom of the three buttons between the numeric keypad and the Touch Screen. The Machine Status screen will be displayed.
  2. Select the [Billing Meter / Print Report] tab on the Touch Screen.
  3. Select [Print Report / List]. The Print Report / List screen will be displayed.
  4. Select [Fax Mode Settings].
  5. Select [Address Book].
  6. Press the [Start] button on the Control Panel. The report will print.
Aug 10, 2010 | Xerox Workcentre M24 Color Copier
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
FLASHING DISPLAY -
The problem on your machine is on the fusing unit, the temperature in the fusing unit is low to start the machine. To cancel the trouble status follow these steps:
Press CONTINOUSLY the following:
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not do again step 1 until the display turns off.
STEP3.press 14 then press print button
The machine will now cancel the trouble status and ready to used. If not canceled and again H4 exist it means that there is a part inside the fusing unit that is busted like the thermostat. With this you should now contact your authorized serviceman to check your machine .
Feb 27, 2009 | Sharp AL-1641CS Copier
Our Sharp AL-1645cs copier shows an H4 command in the display. What does this refer to ? thank you for showing us how to fix this problem. Thanks
The machine will now cancel the trouble status and ready to used. If not cancelled and again H4 exist it means that there is a part inside the fusing unit that is busted like the thermostat. With this you should now contact your authorized serviceman to check your machine .
Feb 23, 2009 | Sharp Office Equipment & Supplies
Sharp sf-7100 / status code
H4 means the fuser can't heat up. The fuser lamp probably burned out. Sorry, nothing can be done without tools and new lamp
Jan 15, 2009 | Sharp AL 1215 Black and White Copier
Konica Minolta Bizhub C550 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
