Question about PetSafe Outdoor Bark Deterrent For Dog
The batteries on our barking deterrant collar, Sunbeam, #F158BN, check "good" but light does not come on.
This collar has two probes that fit over the vocal cords of the dog, a button that activates the deterring sound when the dog barks can be set for Low, Med or Hi. A light on this equipment glows more on Hi, less on Low, indicating the strength of the signal that dog is receiving. The batteries check out as being still strong, the light does not come on. Is the collar sending the signal to the dog? Why is the light not activated? It would seem that the charge from batteries to light is not working. How can this situation be fixed. The barking dog drives me crazy! This collar has the number F158BN printed beside one of the probes. Another number is SBBCUS1. Hard to see as it is molded into the body.
How to stop daschounds barking
to stop dogs barking you have to have the correct environment
they have to be able to see out of their area
they have to have companionship ( other dog as a play pal)
they need to be entertained ( toys )
finally there is a barking collar that can be obtained from a vet or pet shop
it is energized by the bark and gives a small shock to the throat of the dog
IT is effective and is not harmful to the animal and if not used when you are around to correct their behavior the mere fact that when it goes on they will, not bark
Oct 24, 2015 | Cars & Trucks
SET UP BARK COLLAR
Which manufacturer are you speaking about? There are many to choose from.
Feb 13, 2015 | Pets - Others
Stop a dog from biting people
To avoid a potentially life-changing law suit, I think a muzzle might be a good solution.
If the dog barks in advance of biting, you might try a special collar:
2 002results for anti bark collar
Feb 09, 2015 | Miscellaneous
Innotek m041101
If your dog does not bark while it is wearing it!
Aug 26, 2014 | Innotek Bark Control Dog Collar
How do Dog hunting collars work?
If you are referring to remote trainers' collar then please know that all remote trainers have the same basic 3 components: Remote transmitter, Collar receiver and collar probes.
The transmitter sends a radio signal to the collar receiver. Then, the collar delivers the stimulation to the dog through the stainless steel collar probes. The probes are located on the dog's neck and must have direct contact with the dog's skin in order to properly function.
Jan 14, 2013 | Hunting
Innotek shock collar
I had same problem with an Innotek Bark collar. However after my dog s barking caused shocks the first times he wore it and quickly he changed that behavior. It finally and quickly got to the point that I still used it on him but I never had batteries in it as just wearing the collar was enough to stop his annoying the neighbors. These collars do not have a long lifespan like most electronic goods.
Jul 01, 2012 | Innotek Pets - Others
Ultrasmart collar not working
have older model innoteck bark collar w 6 volt lithium battery and magent key...how do i set the levels of stimulation?
Jun 25, 2012 | Innotek IUC-5225 UltraSmart Extra Contain...
My dog barks at everything, and it doesn't matter what time of the day or night My neighbors are always complaining
A lot of people say that these electric collars are cruel, I agree to a certain degree but I have heard of them working when it comes to excessive barking it may be the only way to stop it. I had a friend that told me that her dog was cured from her barking by her using the collar and she would use it again and that her dog hadn't suffered as a result of it.
May 13, 2012 | Pets - Others
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong?
I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
Aug 16, 2008 | Sunbeam 4214 Iron
Sunbeam electric frypan thermostat replacement
IF YOU STILL HAVE THE OLD ONE CHECK TO SEE IF YOU CAN SEE WHAT TEMPUTURE THAT IS WRITEN ON IT IF SO YOU CAN POSSIBLEY GET ONE ON THESE FOLLOWING WEBSITES (WWW.RADIOONICS.CO.UK) OR (WWW.MAPLIN.CO.UK) GOOD LUCK.
Feb 22, 2008 | Sunbeam Kitchen Appliances - Others
PetSafe Outdoor Bark Deterrent For Dog Logo
41 people viewed this question
Top PetSafe Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a PetSafe Pets - Other Expert? Answer questions, earn points and help others
