Artdio connecting rj45 cable
  • 3,320 Answers
What model? Probably not computer speakers.
Posted on Apr 01, 2014
How to manage Ericsson T720G switch?
(1) Console cable if you have desktop
http://www.instructables.com/id/Simple-RJ45-DB9-Cisco-console-cable/
For laptop console to serial cable
http://d32plhejlomyli.cloudfront.net/catalog/product/cache/6/image/500x500/9df78eab33525d08d6e5fb8d27136e95/1/4/14184.jpg
(b) Reset the switch it will work as a normal switch
skype id johnwalker800969@gmail.com
Aug 18, 2016 | Computers & Internet
Missing link between DSL Cable and D-Link Systems HD Media Router 1000 (DIR-657)
What is the Time Warner modem? Make, Model? If you have a Ethernet port RJ45 connect the wireless device via a ethernet cable. You may need a splitter if there is only one Ethernet RJ45 port. Example: http://www.amazon.com/StarTech-RJ45-Splitter-Cable-Adapter/dp/B00009XSZE
Apr 24, 2013 | D-Link Computers & Internet
How do you wire a RJ11 phone jack with cat6 wire??
I assume you are using this configuration to connect a phone and not data outlet.
The RJ11 connector is used for phones and the RJ45 is used for data.
The CAT6 cable has 8 wires and to wire this cable to a RJ45 connector 2 wires on the CAT6 cable are not connected.
Go to this site for a wiring diagram for RJ11 to RJ45.
http://www.google.com.au/imgres?q=rj11+to+rj45+wiring+diagram&hl=en&sa=X&tbm=isch&tbnid=4RlQiCWju6MukM:&imgrefurl=http://ps-2.kev009.com:8081/tl/techlib/manuals/adoclib/aixasync/asycomgd/port128b.htm&docid=zs9vggehEny1kM&w=966&h=680&ei=WWxCTpbYNeL9mAWkpLjVCQ&zoom=1&biw=1016&bih=511
Aug 10, 2011 | Computers & Internet
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
I have a Bose Lifestyle 38. The cable that links the Lifestyle with acoustimas module has been been detached from the RJ45 plasticclip due to move of furniture. The cable is fixed in the walls and not...
i have life 38, looking at rj45, copper facing you (flat side of Rj45),
read left to right
white, brown, space, space, brown, space, white, red.
it looks first white brown runs down one side of flat cable, and the other 3 core brown white red down the other side of flat cable.
Hope this helps you out.
Aug 19, 2009 | Bose Acoustimass 6 III System
Router with RJ45 cable port available
Nowadays most routers come with RJ45 connectors. That is a connector for network cable.
You might be talking about a serial port, found on many security systems.
If you want to connect the security system, you need a serial cable to connect the security system with your computer, and thru a specialized software (more certain provided by the security equipment, be able to perform the task you have in mind.
If this answer helps please don't forget to rate it
Jun 14, 2009 | 3Com Router Cable E1 1200HM RJ45 20M...
How to make RJ11 to RJ45 cable
pls send me your email adddress we are send the doc file of cable crimping proses with color code ......... E-Mail:jilpeshpatel@compudesk.in
Mar 30, 2009 | Computers & Internet
Can i connet my cable network from my p.c to my new macbook
If you have two Rj45's in your PC you can. Cable is connected to your cable modem. Than another cable called a Rj45 (Looks link a over sized telephone jack), connects from the modem to your PC. The simplest & cheepest way would be to buy a splitter for the Rj45 cable. (A lot less money than buying a second network card. Take a look at the link.(Click it once).
http://www.sfcable.com/cable/p/102101.html
You will also need another Rj45 cable to go to your macbook.
http://www.csncables.com/Ethernet-Cables-C9196.html
And lastly, if you want to be able to sit any where in your home & still maintain an internet connection you can buy a wireless router. If your mac has a built in wireless network card.
This is pretty cheep compaired to other wireless routers around.
http://www.buy.com/retail/product.asp?sku=10336386&dcaid=17873
Have more questions, feel free to ask.
Mike
Apr 21, 2008 | Computers & Internet
How do i connect my printer with a usb to a Ethernet (RJ45) cable
Hi Tony,
I assumed you'd like to share the printer on network. I recommend to buy a printer server device that will connect USB port of printer and that device has RJ45 port that can be connected to router or switch hub to share the purpose. Hope this gives you an idea.
Best regards,
Rosener
Jan 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
35 people viewed this question
 Grubhead
Grubhead
