Question about Drills
Hi I was using my Bosch 4 32 hammer drill in - Drills
Hi I was using my Bosch 4 32 hammer drill in breaker mode on some rendering when it just stopped on me None of the functions are working now is there any quick solutions to this
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Check the motor brushes first then the power cord. Two quick checks!
Posted on Apr 22, 2014
  • 3 Answers
SOURCE: drill keeps on stopping and won't restart
Check the cord...sometimes if the brushes are not seated well or if there is a cut in the cord you will run into that problem....If it is not that then possibly you just have a faulty drill
Posted on Mar 12, 2009
  • 3 Answers
SOURCE: my drill bit doesn't remain secure in the chuck of my drill.
grind bits shank in a triangle to let the drill chuck get a better hold of bit but be carfule because this also takes away the drills ability to slip if it hits something solid.
Posted on Apr 15, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
puertobori
  • 7733 Answers
SOURCE: My DeWalt DWD520 Hammer Drill
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Posted on Nov 04, 2010
BOSCH 11247 Hammer Drill will drill but will not hammer. Opened the transmission case and no parts broken but low on oil. Could that be why the drill stopped hammering?
Top up the transmission with PAG150 oil. The Bosch stuff is hideously expensive, but it's the same as the 150-grade oil used in car a/c systems. I fill them so the oil *just* covers the big gear.
Apr 04, 2013 | Bosch 11247 1916" Spline Combination...
Hammer function does not work on Bosch 11224vsr
Its usually a problem with the selector knob... depress the button fully and turn it passed the selection markings and pull it out to remove it
Aug 29, 2012 | Bosch Factory - Reconditioned 7/8" SDS -...
How to fix jackhammer it doesnt hammer.
Bosch hammer drill 11304 uses sds bits and is generally a good hammer. Usually only needs yearly (depending on use) lube with Bosch grease to keep it working well. No hammering usually means lack of lubrication or broken connecting rod on the hammer piston. Not easy to repair. Tackle only if you have lots of experience with Bosch or other complicated hammers. Parts are easy to find. Good luck.
Mar 02, 2012 | Hammering
Runs but doesnt engage rotary or hamer. the machine itself looks in great condition its called bosch buldog extreme.
there is a selector knob on the side that controls the tool functions for drill only/hammer with drill/ and hammer only. make sure it is in the proper setting. If it still doesn't rotate then you have a gear or a broken selector. If no hammer then you have worn o rings or a stuck ram. try the selector first and if still no change please be more specific if no hammer at all, or no rotation even when selector moved.
Mar 03, 2011 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Bosch drill dosent work even when i charged it only used about three times
Hi , try and find proof of purchase ( receipt/credit card statement ) and contact your local Bosch service centre ,in most cases it will be repaired under warranty .
Hope this helps
Mar 12, 2010 | Bosch 13624 24V Cordless Hammer Drills
hi
regards savumihai71
Oct 11, 2009 | Bosch Drills
DRILL FUNCTION BUT NOISY IN USE
Depending on the type of hammer drill you have, the noise should only be heard when you are applying pressure to the material you are drilling. Some drills have 2 bump plates that cause the hammer action. This is what causes the noise. It kind of sounds like the gears are stripped but the chuck still goes just fine. You do not need to grease this, it will make this noise regardless. However you may want to take a look at the gears and make sure they are ok. You may want to add grease if the old grease is broken down or there is not enough in the gear housing. Larger hammer drills have a piston and actual hammer. Such as the Bosch Bulldog series. If it is this type and there is noise when you are in drill mode there may be more serious problems.
Sep 24, 2009 | Drills
Drill just stopped? not working
These tear the brushes out. You can not use them for hammering. It is a design problem.
Replace the brushes and use only for straight drilling.
Jun 28, 2009 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Feb 27, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drills Logo
54 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
