Question about Go Ped GSR Sport Gas Powered City Scooter
Hi, my go-ped won't start, but when I listen to the engine, and right before its about to start, it backfires! MY spark plug works and everything too How can I fix this?!!
Go per isn't too old, the gas and air filter seem fine, i'm not missing any parts and it has worked before
5 Suggested Answers
SOURCE: BladeZ 40cc go-ped doesn't strart... well kinda
clean the carb and make sure it adjusted right
Posted on Feb 06, 2009
SOURCE: My Go-ped will not start
check the coil and the fly wheel for rust or other build up it may not be getting spark also pull the carborator apart and check for varnish. good luck.
Posted on Nov 10, 2009
  • 45 Answers
SOURCE: my mo ped stutters at high speeds
This sounds like a fuel delivery issue. The GSR has a centrifugal clutch, so the sputtering is most likely coming from the engine. There are three main factors; Air intake, Fuel ratio/mixture/delivery, and spark. Check your air/fuel mixture screws first. Then check the Spark Plug, and finally the air filter/fuel filters.
The filters can clog, and starve the engine for air or fuel, depending on the filter. Try to clean the filter, replace the plugs, and adjust the carb. One of these is the verdict, but you must determine which one. Good luck. If you have further tech questions regarding gas powered Go-peds or electric Go-peds, you can visit www.gopednation.com and ask anything there. The most qualified Go-ped Brand scooter technicians and enthusiasts run this site and chat about their experiences.
-Jackson
http://urbanscooters.com/
Posted on Nov 23, 2010
  • 45 Answers
SOURCE: I bought a second hand
Hi Marek,
"Go-Ped" is a Brand of scooter, so if you have a Go-ped, it will say it all over the scooter. On the deck, On the motor, on the frame, etc.
Most scooters with no name, or branding, are Chinese scooters and they usually share the same qualities as many other Chinese scooters. 45cc-50cc Two stroke engines mix fuel anywhere from 25:1-50:1. richer is 25:1, and Leaner is 50:1. You will generally get more power from leaner mixture, but you will also run a higher risk of ruining the engine. 25:1 is richer and safer to run. Anywhere in between is usually safe too as long as you stay towards the richer mixture.
For parts,
I use this Online Electric Scooter Parts Store, as they have many universal parts for Chinese Scooters, and also performance upgrades too. Enjoy.
http://www.partsforscooters.com/s.nl?partner=URBANSCOOTERS
You can also find a repair shop in your area by entering your zip code.
-Jackson
Urbanscooters.com
Posted on Feb 03, 2011
Bike is starting and backfireing,cant give any gas or it will die. this is be couse of lack of gas fro secondary ?
Hi, Michael and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Won Start Just Turns Over And Backfires Fixed
Engine won start backfires out the exhaust
Bike won start just turns over and backfires Any ideas CBR Forum...
Loud bang backfire when starting cold
my bike backfires but will not start Honda Motorcycles FireBlades org
Mar 16, 2017 | GAS Motorcycles
Backfiring but not starting any sugestions?
Hi, Juandre and the usual suspects are:
6. Faulty spark plug cables, leaking or broken, internal damage.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
HELP bike won start
http://www.kiwibiker.co.nz/forums/showthread.php/117473-Engine-won-t-start-backfires-out-the-exhaust
Apr 23, 2016 | Motorcycles
Changed coils on Harley now it won't start just pop or small backfire!
Please remove sparkplugs and hold them on engine connected to cable and check for blue intense spark on both plugs after that when connected and if the engine still does not start if possible please try with a new set of sparkplugs maybe that should do,all provided the coils are engine specific, wish you good luck
Feb 22, 2013 | Motorcycles
Vespa P150X Piaggio won't start
i think it is the CDI-box (at the top end of engine) not working.
check the connectors (pull the rubber cover)
- or better get a new onevespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-0.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-2.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-5.jpg
Jan 03, 2013 | Peg Perego Vespa Scooter
My bike just backfires and wont start
Hi, Hotshot1972 and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary.
http://www.snowmobileworld.com/forums/59-ski-doo/25785-my-sled-backfires-then-won-t-start.html
Yamaha XJ600S 1992 Service Manual
OEM parts for Yamaha
Yamaha Diversion XJ600N Owner Manual
May 19, 2012 | 1995 Yamaha XJ 600 Diversion S-N
My 1990 Harley sportster 1200 is backfiring and won't idle without backfiring can you help?
Hi Anonymous, popping, coughing, spitting, or backfiring through the carburator or induction module is usually caused by air getting sucked in combustion chamber do bad intake seals leaking. Leaking exhaust gaskets can also be suspect. Remove air cleaner and backing plate, while engine is idling spray WD-40 or Brake Kleen around intake manifold to head area, if RPM's increase you have an intake leak and seals need to be replaced, also spark plugs will be burning whiter than normal. Good luck
Jan 05, 2012 | Harley Davidson XL 883 Sportster...
My 2001 toyota tundra is backfiring through the motor. I recently had some freezing problems, and now i cant get it to start and backefires through motor.
car and it spins over but fails to start, there are three fundamental systems that must work properly and should be checked. The fuel and air management is one. Too much or too little of either one of these and the engine will not start. Second is the ignition system. Not only is a spark required to ignite the fuel, it must be delivered on time and in the right place. Last is the engine integrity. It must compress the fuel and air, contain the explosion upon ignition and convert heat energy to mechanical energy to propel the vehicle. A breakdown in any of the three will prevent the engine from starting.
  • Crank the car. Listen to the engine. An experienced driver should depend on his ears and know the sound of the engine. If as it cranks the sounds are abnormal, this is a strong indication of a mechanical failure. Each cylinder, when strong and working well, compresses the fuel and air in proper sequence. When this fails due to a timing belt or head gasket problem, everything sounds different. If the engine sounds entirely different while cranking, mechanical repairs are necessary.
  • 2 Install a fuel pressure gauge. If the engine sounds as it normally does install the gauge, turn the key on and watch the pressure indicator. It should read as high as 50 psi. Refer to the manufacturer's service manual for specifications and fuel pressure test procedures. Some have fuel pressure specs as low as 35 psi. If there is no reading, the fuel pump is in doubt. Turn the key off, and the on again, and listen for a brief, faint hum in the fuel tank. The pump is designed to run, then shut off if the vehicle does not start. If there is no fuel pressure and no hum, the fuel pump or pump circuit has malfunctioned. Make sure there is fuel in the tank.
  • 3 Test the ignition system. Remove a conveniently located spark plug wire from a spark plug and install a spark tester. This is a spark plug with an alligator-clip attached. Clip the tester to the engine. This completes the circuit so the spark can jump across the plug electrode. Make sure the clip is attached to bare metal for a good ground. Have an assistant crank the vehicle and watch for a bright spark. If there is none, the ignition system must be repaired.
  • Dec 04, 2010 | 2001 Toyota Tundra
    My mo ped stutters at high speeds
    Take off Air filter, look inside the carb and pull throttle all the way, the circle should be fully open, if not it may not be getting the full amount of gas it could be, Clean the carb as well, take it apart and clean the mesh filter, To check your plug, just unscrew it from engine, put the cap on the plug, place the tip of the plug on something metal and pull start the engine to see if its sparking. I think you have a carb problem though, clean it and clean your filter and you should be good. If its a stock engine on a goped sport than you should mix 3.2 ounces of oil per gallon. Hope this helps
    Apr 10, 2010 | Go Ped GSR Sport Gas Powered City Scooter
    Oct 14, 2009 | Go Ped GSR Sport Gas Powered City Scooter
    Go Ped GSR Sport Gas Powered City Scooter Logo
    37 people viewed this question
    Top Go Ped Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Go Ped Toy Expert? Answer questions, earn points and help others
