Question about Vehicle Parts & Accessories
Briggs and stratton carb
Gas is in the carb but not getting to the spark plug. what do I do.
    Problem Solver:
  • 17 Answers
If there is gas in the carb, but not getting to the cylinder, then the carb may need a rebuild. Check the air filter; If it is completely clogged then there will be no air to pass through the venturi that would draw gas into the cylinder. You could try backing out the needle screws to see if there is a clog, but if you need to go further (bad float, varnished gas, etc.) you would need to rebuild the carb.
One other thing to check... will it run with the gas cap off? If so, replace the gas cap. Some models have a valve in the gas cap that won't draw gas if stuck.
Posted on Apr 01, 2014
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
My Briggs 675 series want start I put in a new spark plug and I took out the spark and put gas in hole and it still want start
clean the gas out of engine put plug back in get some startinfliuid and sray a little in carb until it starts
Jul 01, 2014 | Briggs & Stratton Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
I have a briggs and stratton 13.5 hp power engine that wont start. The engine is almost new, oil level is good and when I remove the spark plug cap and dold it near the top of the plug and pull start it I...
there may be safety switches, but if you are getting a spark, that is not the problem. After you cranked with no start, is the spark plug wet with gas? can you smell gas in the cylinder after pulling the plug? It could be that your carb float/needle valve are stuck closed. Try lightly tapping the side or the carb.
Jun 08, 2017 | Briggs & Stratton Briggs Stratton Intek V...
We have a briggs and stratton lawn mower that has very few hours on it but has been in storage for the last 5 years, it starts but dies
Clean the gas tank,after a year gas can turn into a gel which will clog the carb,clean the air filter,check spark plug,and readjust the carb(a small screw on the carb
Sep 03, 2012 | Briggs & Stratton Garden
26 hp briggs it is firing and full of fresh gas but wont start.
Well you didn't indicate what its mounted on but the basics are: spark and fuel. Pull a spark plug and make sure you get spark. If you do then it must be fuel. You can try a shot of starting fluid (small amont) into the carb, if it runs on that you know you have a fuel problem. Be sure the carb is getting fuel from the tank. Clean the carb. Maybe a carb kit. With today's fuel, you must take care of your fuel system. Use Sta-bil year round. Fuel can go bad in 60 days.
Jul 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Gas got into the oil through carb. changed oil. rope won't pull. 13hp briggs on a generator.
STOP...The engine crankcase is FULL of gas and oil..NOT A GOOD THING...
remove the spark plug,,,drain the oil.. let the engine "air" out,,, have the carb cleaned and set..
Jan 28, 2010 | Briggs Stratton 020273 Elite Series...
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
