Hotpoint aquaitis 5 yrs old tries to fill with water but just run off into the drain pls any ideas
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Could be the Pump. Caontact Hotpoint.
Posted on Mar 31, 2014
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
duby1990
  • 370 Answers
SOURCE: Won't spin or drain
Check to make sure your lid switch is working.
Posted on Nov 17, 2008
SOURCE: Hotpoint washer won't drain water out
I have a top loading hotpoint and a feather blanket broke open and the washing machine would not drain or spin.
I had to empty it by hand(syphon and scooping), then unplug the washing machine and un hook the drain pipe and water hoses. I then tipped it over and unsrcrewed all the screws to find the pump. There should be a black hose going into it. You must take that black hose off by loosening the clamp. Once I took that off I could see the pump completely clogged with feathers. I removed the feathers and hooked everything back up. It took me about 25 min to do the entire process.
hope this helps.
Posted on Jan 19, 2009
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
My Bosch dishwasher is not draining water and thus leaking on the floor. It is 7 yrs old but only has been used for 3 yrs as I was away. It was run weekly in my absence. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Dishwashers
I have a very old (16 yrs +/-) whirlpool washer that tries to fill with water, but seems to drain straight out. Unfortunately, the first time I noticed the problem, I started a load of wash and left...when...
You probably have a floor drain rather than a drain pipe which is higher than the pump. hold the drain hose up while its filling or make it go up (about as high as half the machine height) before it goes back down to the drain. (At least to check it out) The pumps shouldn't siphon out but some do.
Aug 20, 2009 | Whirlpool Washing Machines
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water starting to pool (two tablespoons) under front of frig under door, is there a pan in the bottom of this unit?
Most fridg's have a water pan below. Need to drain occationally, especially after defrost cycle.
Apr 30, 2009 | Refrigerators
Machine just won't start
you have probably a bad lid switch
Dec 28, 2008 | Maytag LSE7806A Top Load Stacked...
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
NOT FILLING PROPERLY
have you got the drain pipe going up to about worktop level of machine?
if the drain just goes downwards then the water just runs out as fast as it comes in. get a sililiar situation if you put drain pipe too far down a standpipe - then a syspon forms and water drains out
Jun 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
