Question about Toro Garden
It there a timing mark for a toro lawn mower gts195cc?
Want to know if there is a timing mark for toro 195cc small engine
  • Toro Master
  • 15,947 Answers
Usually there is not. The timing is through the flywheel that connects to the crankshaft and it is permanently set with a woodruff key. When evereything is tight, the timing is good. IF you hit something and cause the blades to stop, the flywheel can move and twist on the shaft and bend the woodruff key. The engine then wont start or will backfire etc. To fix this you need to pull the flywheel off the crankshaft and replace the woodruff key and reinstall it.
Posted on Mar 31, 2014
I have toro 195cc tec carb. Mower runs one.minute then cuts out. Have good spark. Replaced carb. Removing fuel cap doesnt help. Carb jet is clean. Swapped plugs with another toro. What am i missing?
Tankfilter (sludge problem) Gasoline faucetfilter the fuel hose connections , fill up your oil level if in doubt of it after know the right level try to unconnec for only a short time the Oil monitoring cable
May 13, 2017 | Toro Garden
Lawn mower batter charger blows circuit breaker
I'd try plugging it into another outlet first, then try turning off any other appliances that might be on that same circuit. If it continues to trip the breaker, I'd take it to the small engine shop.
hope this helps
Apr 19, 2014 | Toro Garden
What does the woodruff key look like on toro 195cc lawn mower
Not sure what you are asking. Electrical switch? or this, here is a woodruff key that locks a shaft to a gear or wheel etc.9k=
Apr 01, 2014 | Toro Garden
Setting timing marks
Most small engines do not have timing marks. If your timing is off, its usually due to a sheared flywheel key, you can check this by removing the nut on the flywheel and seeing if you can tell the key slot on the flywheel lines up with the slot on the crankshaft. New keys are very cheap. If you are still having ignition problems, the problem would be in the ignition module. Also check your plug, just in case.
Mar 31, 2014 | Toro Garden
Toro gts 195cc
I USE THE PART LIST DIAGRAM TO PUT THINGS BACK TOGETHER.
Jun 27, 2013 | Garden
Where can i find the kill switch cable for a toro lawn mower
Try a rental store, or any small engine repair shop... They'd be happy to order it for you!
Sep 11, 2011 | Toro Power Lawn Mower
BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER THE ENGINE IS A TECUMSEH MODEL lev120 SPEC 361541b 195cc
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
Sep 23, 2009 | Toro Lawn Mower With Toro Power Tools
Antique toro riding mower need parts for restauration
Jacks Small Engines. in Maryland
www.jackssmallengines.com/toto_parts_index
or www.WiseSales.com
That is where I got the parts for my 17 year old Toro riding mower
Sep 01, 2009 | Toro Lawn Mower With Toro Power Tools
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
Garden Logo
74 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
