Question about Ricoh Office Equipment & Supplies
Ricoh Aficio SP C430DN - Print Data Error
Ricoh Aficio SP C430DN (networked) installed fine on computer running Win 8.1, communicating with printer, but doesn't print - only gives the error "Print Data Error." Have tried different drivers, installing with wizard, manually and with Bonjour for Windows, etc. Other computers on network printing fine to the same machine. Any advice?
  • Merrick Kingman
    Merrick Kingman Apr 01, 2014
    Also, was installed as administrator,
  • Ricoh Expert
  • 393 Answers
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Posted on Apr 03, 2014
  • 1 more comment
  • Merrick Kingman
    Merrick Kingman Apr 04, 2014
    I've tried all of the drivers listed on the Ricoh site, including PCL 5, 6, PS and Universal. Also tried the Print Class Utility. Have uninstalled each old driver and re-started before trying each new set of drivers. I've gotten this printer to work on this computer in the past.
  • quennie732 Apr 04, 2014
    Do you have 8.1 64 bit or 32?
  • Merrick Kingman
    Merrick Kingman Apr 07, 2014
    Running 8.1 64 bit. Sorry I forgot to add that in the original post. :)
  • 54 Answers
SOURCE: Windows Vista Printer Driver
Go to: http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
and select the copier and OS that you use. Download the PCL5e driver. When you finish downloading, you might have to extract it from the zip format, then run the setup.exe file and follow the prompts.
Don't forget to rate your answers please!
Posted on Mar 16, 2008
SOURCE: Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Posted on Aug 29, 2008
SOURCE: Mac OSX 10.4.11 won't print to Ricoh Aficio CL2000n network printer
As an update:
I actually had a Ricoh tech come out to my house. It was a warranty service - I was very impressed! He did some fiddling around, said that there was no problem that he could detect but... after he left the Macs can print to the printer no problem. From what I can recall, all of the settings were identical to what they were in the first place on the Mac side.
I still can't get my linux machine to print there but it is a low priority and I am really not trying very hard.
I wish I had more enlightening input.
Posted on Nov 24, 2008
SOURCE: Error: Printing data is inaccurate, printing processing is stopped
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
Good luck!!
Posted on Dec 05, 2008
SOURCE: Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Posted on Mar 26, 2009
HOW TO OBTAIN PRINTER READINGS FROM MACHINE RICHO AFICIO SP C430DN
Hi.
You will need to print the Printer configuration page.
The procedure is;
Menu > Printer Features > Configuration page.
You will see it in the top.
Nov 18, 2016 | Ricoh SP C430DN Laser Printer
Aficio SP C430dn Will not print graphics correctly only text.
Replace the drum and drum wiper blade also use genuine tonner catridge..
May 07, 2016 | Ricoh Aficio Office Equipment & Supplies
How do I get a Machine Administrator logon for our Ricoh Aficio SP C430DN printer?
Hi, sorry if my response sounds like a question, does not the machine administrator status not allude to the status of the account logged into on the Mac? A windows administrator is somebody that has control privileges in an account . I think I am asking whether the privileges referred to are on the Mac rather than on the printer?
I have never used a Mac but on a windows machine all Iwould is uninstall all the software, detach the machine for a work session then reattach and reinstall the software.
Hope this does not sound too......?
Good Luck, hope you get a better response.
By the way, drivers for this in Mac format are available on the ricoh website
May 29, 2015 | Ricoh Aficio SP C430DN Color Laser Printer
Aficio sp c430dn error sc670. In service manual prepose to replace engine board. But i can find it. Is in SM engine board called Controller board? Also am trying to upgrade firmware. When I put in the
You cannot update firmware when there is an error condition. Reseat all the connections on the controller board. If it still fails then replace part number D0655715.
Nov 28, 2014 | Ricoh Aficio SP C430dn Laser Printer
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
Aficio C430DN error SC540
this is a problem with the fusing section
call an expert to check on it for you
Mar 06, 2014 | Ricoh Aficio SP C430DN
Horizontal black lines on print jobs Ricoh SP C430DN
Are theses along the border? You may need to replace the Black Drum unit
Dec 20, 2013 | Ricoh SP C430DN Laser Printer
Ricoh aficio sp 4210n installation
if u hv win 7 or 8 it will install automatically
Jul 18, 2013 | Office Equipment & Supplies
I am unable to connect to my Ricoh Aficio 2051
Try turning the printer on/off after you have installed the printer on each machine.
Nov 20, 2008 | Ricoh Aficio SP-C210SF Printer
369 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
