Question about Toro Garden
Setting timing marks
I want to know if it's has a timing mark on the engine
    Problem Solver:
  • 7 Answers
Most small engines do not have timing marks. If your timing is off, its usually due to a sheared flywheel key, you can check this by removing the nut on the flywheel and seeing if you can tell the key slot on the flywheel lines up with the slot on the crankshaft. New keys are very cheap. If you are still having ignition problems, the problem would be in the ignition module. Also check your plug, just in case.
Posted on Apr 03, 2014
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: timing marks on a 6.25 hp engine
This should help you out:
http://engines.myfaqcenter.com/Answer.aspx?p_faqid=4&selectCats=Troubleshooting - Repairs
Posted on Jun 13, 2010
How do i set the timing of victa altima lawnmower,i just want to know where the mark of crank shaft and cam shaft must point? it is a one piston engine with two valves
There is a mark on crank gear, and there is a mark on cam gear. These two marks may be a circle, a dot, a triangle or possibly something else. The idea is two marks must be placed together for gear timing to be correct. I hope this is what you are asking. Please let me know how you make out. GOOD LUCK FRIEND.
Jan 10, 2015 | Garden
Timing marks 1993
spark or cam ?????????????????
and which engine, some cars have up to 10 choices.
most are about 3 or 4.
not of this can i guess.
May 29, 2014 | 1993 Pontiac Grand Prix
I need to know how to set timing belt 4 cy 2.0liter with to cams
Would help if the vehicle details were included ,like what type of engine as on modern cars their is no timing marks on the gears anymore neither is their any keyway on the gears either they are a taper fit ,if you post the engine type then i should be able to tell you what to do ,if i dont know this engines timing marks i will instruct on how to set up engine with no timing marks at all
Nov 23, 2011 | Cars & Trucks
Engine Timing marks on a 4.0 ford ranger on a 2005
Rotate the engine so that No. 1 cylinder is at TDC on the compression stroke. Check that the timing marks are aligned on the camshaft and crankshaft pulleys. An access plug is provided in the cam belt cover so that the camshaft timing can be checked without removal of the cover or any other parts. Set the crankshaft to TDC by aligning the timing mark on the crank pulley with the TDC mark on the belt cover. Look through the access hole in the belt cover to make sure that the timing mark on the cam drive sprocket is lined up with the pointer on the inner belt cover.
Nov 02, 2011 | 2005 Ford Ranger
When setting the ignition timing on a 1991 ford ranger 3.0 were dose the rotor need to point, after number one or before number one? the engine is on top dead center
The engine timing markers down on the harmonic balancer/crankshaft pulley should be aligned with the timing indicator on the engine block to "0" degrees when the engine is in the compression stroke for the #1 cylinder, and this is TDC or "Top Dead Center". When something blows out of the spark plug hole that only means that the piston is coming up on TDC, but the crankshaft will still have to be turned until the timing markers are at "0" degrees. You should be sure that you do know how to properly align the timing marks to "0" degrees, and the timing marks must be set at "0" degrees before the distributor can successfully be installed.
Be certain that the timing marks are set at "0" degrees and on the compression stroke for the #1 cylinder, or the timing will be 180 degrees off when you install the distributor. This has to be precise and guessing will not get the distributor properly clocked in so that the ignition timing can be correctly set.
Once you are certain that the timing is set to "0" degrees "TDC", then mark the distributor housing where the #1 position on the distributor cap will be when the cap is installed on the distributor, so that the distributor housing shows a reference mark where the #1 position is, then the distributor should be installed so that the ignition rotor is pointing directly at the #1 position on the distributor housing, or just before the #1 position mark according to the rotation of the ignition rotor. The distributor should be able to turn and point the ignition rotor on either side of the #1 position mark to provide plenty of timing advance or ****** so that the ignition timing can properly be adjusted to specifications after the engine has been started.
Be sure that you follow the proper timing procedure for that vehicle and remove any timing spout connectors that are described in the set timing procedures
Also, be certain that you are actually using the #1 cylinder to set the engine to TDC and to actually time the engine with a timing light. Here is a firing order diagram that should also help to assist you. Let me know if you require any further assistance.
Jun 17, 2010 | Ford Ranger Cars & Trucks
1999 chevy 4.3 timing issue
i have a 1999 blazer 4.3 2wd i have top dead center up and the mark on the balancer lined up to the cover. Ignition rotor pointed to #6 on the cap. But it still seems like its out?
May 26, 2010 | 2000 Chevrolet Blazer
91 f150 4.9L no visible timing marks, hard start runs rough.
I have wondered why this happens many times in the past. You would think the marks should line up using #1 cylinder but they don't.
It has been a while but I think if you hook up to #5 ignition wire the marks will come up for you.You will need to undo the "spout" connector before setting it to 10 degrees before top dead center. The spout is a two wire jumper clip that should break out of the harness at the distributor.
Warm the engine up for a while so it doesn't stall as easy while you set the timing.
Nov 03, 2009 | 1991 Ford F150
Where can i find the timing marks on 1998 ford escort zx2 ?
Hello pamgolmon: My name is Roger and i will answer your question. The 2-0 dual cam engine is a interference engine. This means if the engine jumps time at the timing belt. It will bend the valves. As for the timing marks on the camshafts. Their are no marks to be located. To set the timing marks on this engine requires special tools. This makes it expensive for not only the do it yourself mechanic but also the repair shops also. If the valves were bent you must pull the head for the repairs also.
I know this is not the answer you were hoping for but it is the only answer to give. Please rate the quality of the answer as this way we know your answer was correct. Please just ask if you need further help. Thank You for using Fix Ya. Roger
Sep 09, 2009 | 1998 Ford Escort
Setting timming changed headgaskets timing marks up top set but bottom timming mark keeps movihg 15 deg btdc even know start at 5 deg rottor button set on number one but does not start . sounds like it is...
Put the engine at TDC compression stroke , Thats when the valves are both closed on No 1 cyl and the piston is on its compression stroke .then align all cam and crank marks. set distributor/rotor button on No 1 cylinder (rotor pointing at #1 plug wire) . rotate engine 2 revolutions and recheck all marks. Fire away
Aug 25, 2009 | Mitsubishi Passenger Cars & Trucks
1998 xc70 volvo timing marks
fFirst of all you must replace the timing belt with new. The second problem you have is it sounds as if you have not set the engine, to the correct position before you removed the belt, it is very difficult to set the marks without everything moving together. If you move one camshaft without the other one moving in unison you will bend valves. I also need an engine code for the correct timing marks. as there are 2 options for this vehicle. It may be cost effective at this stage to employ a good technician to finish the job for you. But if you can give me the engine code i will send the info.
Dec 24, 2008 | 2006 Volvo XC70
Garden Logo
73 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
