Question about Haier HL32R 32 in. LCD TV
There is no color on tv when cable is connected....there is otherwise when tv is not connected to the cable
What should be done in light of all of this....I tried unsuccessfully to connect a PS2 and all of the sudden the problem became apparent...
  • Kd Mcj
    Kd Mcj Mar 31, 2014
    thanks folks for your time and attention..managed to get things figured out...
  • Haier Master
  • 3,320 Answers
A Playstation2?
The cable you are using doesn't match the TV input.
Posted on Mar 31, 2014
How can i connect a video camera to play through tv. my camera cables are red-white-and yellow. tv. is white-red- green-green-and red.
Your camera has three cables, red and white for stereo audio, and yellow for what is called composite video. Composite video puts the three color signals into one composite signal. Your TV sounds like it has a component video connection, which wants all three color video signals separated onto three plugs. They are usually color coded green, blue, red. Not sure if you mistook a blue outlet for green..... In any case, on my TV, it will allow me to connect a yellow composite signal to the green component jack, the first (leftmost) of the three component video jacks. Not sure if your TV will work this way, but it is worth a try. Otherwise, you can look up accessories for your video camera and see if it can output true component video and stereo audio, but I tend to doubt it will.
Aug 27, 2014 | Televison & Video
Walter and Barbara Bradford calling back with additional info. The cable box is explorer 4250HDC.It is hooked to the TV with 5 cable hookup.Also there is the power wire and the cable that goes to the box...
what are you trying to do? to hook up the tv you can use the cable output from the charter box into cable input into the tv (meaning cable as in coax cable) otherwise you can use the colored ones. red white an yellow are rca jacks but the 5 wire you talking about are prob compondent cables which are red green and blue. connect those to the tv and the other red and white ones are for audio to the tv you may have to set the charter box to select which output you are using and the tv to the right input for the rca it will prob be input 1 for the component it will be component 1
let me know if thats what you needed
Mar 17, 2011 | Craig CLC501 15 in. TV
When i turn it to tv it has color but when i turn it to my wii it shows no color just black and white and YES i have a color tv !!!! help !!!!
This problem typical indicates that there is an issue with the connection from the Wii to the TV. This problem can result from a few different situations. The most common cause comes about when the ends of the RCA or Composite cable are connected incorrectly. Both cables are color coded so make sure there plugged into there corresponding inputs (Blue and green can look very similar in low light). Another common problem is when the RCA cable is incorrectly connected to a composet cables set up inputs. If the wire your using has the colors white, red, and yellow than it's an RCA. If the wire has red, green, and blue than it's composite. Composite cables are used for HD TV's. If you do not have the correct cable for your TV one can be purchased at target or any similar store.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 29, 2010 | Video Game Consoles & Games
Vcr hookup
Try using a S-Video cable if your VCR has the connection. Otherwise, use a RCA composite-video cable on one of the AV inputs of the TV. The cable has a Yellow, Red, White color, the same as the jacks it goes in.
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Don't know how to connect my vcr to my tv
You can either plug RCA cables from the audio and video, audio is red and white for stereo or just one of them for mono, the video is yellow, from the "outputs" on the VCR to the matching colors on the tvs "inputs". You can also connect the antenna output on the VCR to the antenna input on the tv and put the tv on channel 3 or 4, if done this way connect the antenna/cable to the VCR antenna in and connect a cable from the antenna out to the tv.
May 27, 2009 | Televison & Video
Color stream not working
First try different cables for the video. You can use an audio cable for testing. It seems like the green channel is not making a connection. I'm assuming otherwise the set works fine?
Nov 21, 2008 | Toshiba CX32H60 TV
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Rca sound system hooked up to the tv the dvd pictures is black and white
I see three possible problemos:
1: You are using a composite connection and your tv is downright crappy at displaying a composite feed--I know mine is. Try upgrading to component if your tv supports it. If not use a s-video connection.
2: You are using an s-video connection and there is some connection problem, either in the DVD player, the cable connectors, the cable itself, or the s-video input on your tv. Upgrade to component if your tv supports it, otherwise try the cable and DVD player out on another tv to see if the tv is the problem, or use the cable on a different DVD player to see if the cable is the problem.
3: You are using component input only two of the cables are loose OR you are only using the green-colored cable. Either plug in all three component cables (red, green, blue) or try pressing the cables in while watching to see if that fixes it. You may need a better cable, some of them are crappy at staying in.
Apr 06, 2008 | Televison & Video
Vertical line
Sorry, you have a defective LCD panel. If your TV is still under warranty, contact Sharp to get the TV exchanged. Otherwise, LCD panels cost more than the TV is worth.
Mar 25, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Haier HL32R 32 in. LCD TV Logo
96 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
