Question about Art.com Premium Giclee Print "I cant remember which one of us is me." - New Y
Mikuni carb diagram id. #'s 83l01b l2z6 pls advise application and kit #.thx.
In back of shop, no one remembers
Diagram of mikuni carbs
clockwise for leaner mixture( it's really and air/fuel mix)
Jul 07, 2014 | 1990 Yamaha XTZ 750 Super T?n?r?
Mikuni ucal carburetor pipes diagrams
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
OEM parts for Yamaha
http://www.dt125.cz/download/Owners_Manual-DT125X_RE.pdf
Yamaha DT 125R
http://www.dirtntrial.com/tuning.htm
May 18, 2014 | Yamaha DT 125 R Motorcycles
Get a diagram for Mikuni Carb 42 through Internet!
Apr 26, 2014 | 2005 Harley Davidson FLHRI Road King
Mikuni carb
Hey Anon,, WHY are you needing to replace the carb?? In my 40+ years of being a motorcycle/atv mechanic, I have only replaced 3 carbs,,,and CLEANED and repaired HUNDREDS AND HUNDREDS. reply to me on here.... I'll help you
Jun 28, 2017 | Suzuki 2005 QuadSport Z400
Mikuni ucal carburetor diagrams
Many things can cause this;
check the following.
1. trash(including rust in the tank if metal) in the tank/carb. If the carb set for more than 6 months it may need the fuel system cleaned out(includes the carb). Putting a filter in the system will not take care of the rust problem in most cases. If the tank is metal and has rust it will need a tank liner kit like the brand "kreem" or the equivalent.
2. the needle/seat combination and/or float is incorrectly set or bad causing that fuel level to get high in the bowl. Check the float height according to the manual or replace the float/needle/seat.
3. bad seat o ring if it has one and also a petcock that does not shut off. If you can jog the seat around in the carb, then the o ring is probably bad. If you disconnect the fuel line from the carb and gas still comes out, the petcock is most likely bad or it has trash in it.
Jul 14, 2013 | Mikuni Motorcycles
Can't find a rebuild kit for 1996 royal star mikuni carbs
no kit, but all parts can be ordered, try www.mrcycles.com
Oct 02, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
Mikuni jetting
If it's the Sreamin' Eagle Mikuni, it should come jetted close enough to take your bike to someone with an exhaust gas analyzer. That's the best way to get your card jetted correctly with the extensive amount of changes that you have made on this bike. I would advise that you take the bike to someone that has a dynometer that is equipped with an EGA and have the run the bike up. I would not want the mixture to exceed 14:1 at any time and preferrably run about 13.5:1. It's a bit on the rich side but it will help keep your engine running cooler. I've installed the carbs before but I cannot remember what jets they had in them. Sorry. Good Luck.
Jan 21, 2010 | 2003 Harley Davidson FLSTF Fat boy
Fuel wont spray inside carburetor
Try tapping the side of the carb.while some one crank's engine, the float could be stuck, if you buy a rebulit kit it will have the diagram with the kit.
Jan 21, 2010 | 1987 Honda Civic
I have a used 2005 Spotster 1200cc Custom, with Mikuni Carb. The plunger in carb is stock HD plunger (not the one came with car kit, so said tech guy), which cause choke left open. I am trying to find and...
The stock harley choke plunger will not work on a Mikuni carb! It causes the carb to run rich all the time! You can go to a GOOD Indy in your area and order the Mikuni plunger. It is listed in the DRAG book
Aug 03, 2009 | Harley Davidson XL 1200 C Sportster Custom...
Art.com Premium Giclee Print "I cant remember which one of us is me." - New Y Logo
195 people viewed this question
Top Art.com Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Art.com Office Equipment and Supply Expert? Answer questions, earn points and help others
