Question about Krell Audio Players & Recorders
Hi, my Krell KSA 150amp is running cool any suggestions as to why. Many thanks
Amp has been running cooler for a while, then got really hot now even after running it for a few hours it doesn't even get luke warm, I've read somewhere it could be capacitors drying out could this be true ?
    Top Expert:
  • Krell Master
  • 75,386 Answers
Audio output section circuit draws enormous current at idle stage. Contact any service electrician to detect the fault and get it repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Posted on Apr 01, 2014
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Dead amp
Hi Ingemar... sorry for the delay getting back to you. It sounds like you may have a problem with transformer connections, or maybe orientation of a bridge rectifier. Check all connections in the power supply with particular attention to these. Check also that th3e caps are fitted the correct way around. Look also for hairline fractures in the PCB about the power supply. I am trying to find a circuit for your model at the mo. Not having much luck...do you have one you can link me to or upload to FixYa? Would get me on the same page as you to really get into the problem.
regards
Graeme
Posted on Mar 13, 2008
  • 31 Answers
SOURCE: krell 250a power amp
Hi There WLAW,
I am in Auckland NZ and do repair work for a high quality Amplifier chain so I could have a look at yours for you....
Being Local in Auckland it will save you sending it away off shore to Australia.
Cheers From YUBEUT (09) 357 7496
Posted on Dec 26, 2007
  • 185 Answers
SOURCE: convert to 220v krell amplifier ksa-250
if it is conertable to 120v there will be a tap on the transformer input for that
Posted on May 27, 2010
micromatikal
  • 2777 Answers
SOURCE: I need to connect a
You will need to use the pre-outs on the receiver to hook up your amplifier. I am trying to verify if that model even has pre-outs for the front channels, many do. You will be able to tell quicker than I can by just looking for outputs labeled pre-out for the front channels. Just use the cables you have to attach the Krell amp to those pre-outs and you will be good to go. Let me know if you are unable to locate them... the receiver may not be designed to do that..
Tim
Posted on Sep 15, 2010
Where can I get a fuse for my Krell KSA 300 amplifier.I had a blown fuse on the left channel.
Fuses rarely go on their own. The cause is likely to be a shorted semiconductor device in the left channel output.
Fuses are generally not specific to any brand. Is the fuse a tube with metal ends? If it is measure the length in MM. Then look at the end and you should see the rating. Either in A for Amps or MA for milliamps.
Any electronic parts supplier should have the one you want in stock. Buy several, for if the part I mentioned has gone, it will blow again.
Sep 09, 2016 | Krell Audio Players & Recorders
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
Hi! My neptune tl does not seem to have very hot water. I run the washtub next to it until the water is hot, but if you pause the machine, the water that it is filling with is really cool. Cooler than...
What happens if you turn of the cold water valve at the supply and do a hot fill....leave the Hot water supply valve open? Do you hear water filling the wash tub or do you error out with a NF error code for no fill?............. D*ick
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Convert to 220v krell amplifier ksa-250
May 13, 2010 | Audio Players & Recorders
My transmission line that connects to the radiator
The easiest fix is to get a transmission fluid cooler & use it to replace the fan connection completely. Basically you'll just shorten your lines a bit to clamp a hose over them & connect both lines to the 2 lines on the cooler. the cooler installs onto the front of the radiator with push through connectors that makes it easy to install & it will provide you even better trans. cooling in the warm months.
I have seen people use just a hose to connect the 2 lines & not have any problem in the cooler months but you really do need the trans fluid cooled during the warmer months to prevent trans damage.
check you fluid & top it off properly after making the repair!
Good Luck
Jan 27, 2010 | 1996 Chevrolet Cavalier
Dead amp
regards
Graeme
Mar 11, 2008 | Audio Players & Recorders
Krell 250a power amp
Hi There WLAW,
Dec 26, 2007 | Krell Home Theater Standard 7.1...
Suitable CPU air cooler
I suppose you have done your homework as to if u really *need* to buy a new cooler. Is ur CPU getting HOT? what temperatures does it run at? Your choice of cooler depends on what you plan to do with it. Do you plan to overclock your system? I would suggest a Coolermaster stock copper cooling system. Zalman is also good but expensive. But as i said depends on what u wanna do with the system and if u really need that extra cooling if you dont plan to overclock your system.
Dec 24, 2007 | EliteGroup ECS P4M800-M Socket...
214 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
