Question about Exercise & Fitness
Belt relacement how to replace the belt and where do I get a belt?
  • 914 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH We may have what you are needing. Just go to the above link with your model and serial number readily available.
Posted on Sep 18, 2015
All power is good, heats up but drum won't turn. Hear humming noise after pushing start button. Relaced motor,thermal fuse and thermistor. Still nothing. Checked door switch. Any other suggestions?
Betty,
When you replaced the motor, did you also replace the belt? If you had not said that you already replaced the motor, I would have suggested that the belt was broken.
Jun 09, 2015 | Kenmore Dryers
How do I relace brush belts
turn it upside down and remove the cover . quite simple to get to belt and replace . pay attention to direction of twist or when you get it together the brush will run backward
Feb 08, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I replace the dryer belt on a kenmore 70 series dryer
remove two phillips screws under lint screen trap door pop lid up... remove two corner screws usualy 5/16 nut driver lift upward and off to the right idler pulley bottom left pat attention to belt routing before taken off relace pulley change belt and repeat steps and reinstall
Jan 31, 2011 | Kenmore Dryers
If the timing belt breaks on my 2003 Mitsubishi Montero Sport....will I have to replace entire engine....or will it just stop running?
new engine.....or you could relace the belt every 60k/5years...forget makers recc,they dont pay the bill when it breaks....
Sep 11, 2010 | 2003 Mitsubishi Montero Sport
A whining noise coming from the pulley system
Whines and squeaks are usually from worn belts. Spray belt dressing on power steering, a/c compressor, and alternator belts When belt noise goes away on particular belt check for fraying and cracks. Relace belt and adjust belt tension as noted.
Apr 10, 2010 | 1998 Chevrolet Malibu
Fans don't work after relacing serpintine belt.
look around the wiring and sensors when belt broke some debris may have damaged or disconnected the circuit
Feb 14, 2010 | 1993 Buick Park Avenue
Looking for diagram on how to replace fan belt(alternator), on 1997 Prado RV-6
its got 2 belts drop lower shield drop condensr pulley then take out battery 8 bolts that hold in battetry box then 14mm adj bolt to alt then change belts tighten relace all.about an hour if not on driveway.battery box needs to be out to get room for alt
Nov 23, 2009 | 1997 Toyota Land Cruiser
1998 Kia sportage 4wd 2.0 dohc, is this non interference engine
NO NEED TO REPLACE CAMS OF SHAFTS, AS LONG AS VEHICLE WAS WELL MAINTAINED, MIGHT HAVE TO REPLACE BELT TENSIONER.
Mar 26, 2009 | 1998 Kia Sportage
Need procedure to relace timing belt
You best bet is to buy a repair manual.
Feb 27, 2009 | 2000 Volkswagen Jetta TDI
A/c belt relacement
DO this with a COLD engine, so you do not burned by a hot engine...Loosen the 14 millimeter nut on the idler/tensioner pulleythat the AC belt rides on. Do NOT remove the nut, or the pulley will fall off. Then loosen the long 12 millimeter bolt, which will remove tension, and will let the pulley extend. Remove the old belt. Spin the tensioner pulley with your hand, make sure that it spins free & is not noisy, Fit the new belt, and tighten the 12 millimeter bolt until the pulley retracts,and tightens the belt. Finally, retighten the 14 millimeter nut.
Dec 31, 2008 | 1995 Toyota 4Runner
Exercise & Fitness Logo
102 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
