Question about Weber Grilling
I have a Weber Genesis S-330. My house has a natural gas pipe out to my deck with a shut-off value. Do I need to buy a seperate part to connect the hose to the gas line? Can't seem to figure out how i
Need help connecting Genesis S-330 to my natural gas line.
  • 494 Answers
Hi Jamie Duke, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Did your grill come with a grey rubber gas hose and/or a quick-disconnect fitting? The quick disc. (typically 1/4", 3/8" or 1/2" size) should hook up to your shut off valve, but you may need to buy a pipe fitting to adapt to it, that is, if the shutoff valve is not the same size. Let me know if I can be of any assistance. Douglas
Posted on May 31, 2014
heatman101
  • 43501 Answers
SOURCE: Natural gas regulator
No.. the gas pressure that is run out to the grill should be low pressure allready...just hook it in leak test it and you are good to go....
My grill sits right by my meter about six feet away... I tee'd off at the meter installed a valve and then run right into the grill....works great!!
heatman101
Posted on May 29, 2010
  • 494 Answers
SOURCE: converting weber natural gas grill to LP Gas
You will need to replace the orifices and install a propane regulator and hose. Plus, of course, you'll need to buy a 20# cylinder. I looked up your grill serial # and found a parts explosion for your grill. Here is the link: http://www.weber.com/PublicSchematic/view.aspx?model=6821001
If you click on the "additional parts" link, they have the conversion kits listed, but none of them are available anymore. As a propane guy, your best bet is to take it to a local propane co and have them convert it to propane for you. They will drill out your existing orifices and install spuds, and then re-drill smaller holes for the appropriate BTU rating for each burner. Then they can install the regulator and hose and even sell you a new and full 20# cylinder. Call around first and see which one can help you, as not all have serviceman that can do this particular job. Hope this helps. Douglas
Posted on Jun 07, 2010
  • 4736 Answers
SOURCE: What is the NATURAL gas flow rating CFM for a
Dennis, it's not the CFM you need to know, it's the water column inch that is required. In this case it's 7 inches. Also, if you're burying this 40' run, you can't use black iron pipe. A less labor intensive and perhaps less expensive way to go is 1/2" Flexible Copper Refrigerant Tubing. It's comes in 50' & 100 ' roles from your local home center. Even if you're not burying the line, it's a better way to go, as you'll have fewer fittings that could be prone to leaking. I
n addition, you'll also need and an inline gas shut off valve at the connection before the grill and a 12' long quick disconnect gas hose, that connects to the copper pipe connection at the shut off valve and then to the grill. This is a code requirement.
Now, with all this said, I hope you have a Genesis S-330 Natural Gas Grill. Because, the Genesis Propane Grills ARE NOT convertible to Natural Gas. And Genesis Natural Grills ARE NOT convertible to Propane.
Hope all this helped you make the right decisions. Have a great day and Happy Grilling!
Posted on Apr 13, 2011
  • 4736 Answers
SOURCE: Bought a weber genesis 320 Problem with the Weber
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
Posted on May 08, 2011
  • 4736 Answers
SOURCE: i need to convert my
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
Posted on May 14, 2011
Conversion
Click on the Weber link below for customer support and the nearest location that can service your grill. http://support.weber.com/ Weber com Parts Support
Oct 15, 2013 | Weber Grilling
I have a genesis model 320 natural gas grill what
change all the gas orffices and the reg , try Calgary bbq center for a kit they are on line .
Sep 07, 2011 | Weber Genesis E-320
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
May 14, 2011 | Weber Genesis Silver B Grill
What is the NATURAL gas flow rating CFM for a Weber Genesis S-330 grill at 60,000 BTU max? I will be using 1/2" black pipe 40ft long run to the grill off a 3/4" main line - ok? Thanks...Dennis
Apr 13, 2011 | Weber Grilling
Unused natural gas piping
Check with your fire department inspectors, or your gas company. Every State has different codes.
Feb 19, 2010 | Weber Genesis Silver B Grill
Kit for converting weber genesis silver c to natural gas
Some grills do not have conversion kits, if your grill is labeled as dual fuel you can contact weber and get a kit for it.
Dec 31, 2009 | Weber Genesis Silver C Grill
Converting Weber Genesis Silver B from LP to Natural Gas
Hello...I have the same grill and want to do the same conversion...From my research, you need to drill out the three orifices with a size #53 wire gauge drill bit. ( this resizes each orifice to 12000 BTU's each, which the grill is rated at 36000 BTU's).Then remove the existing hose and regulator. Replace the hose with a Quick disconnect compression fitted hose. The NG supply needs to have a pressure regulator installed, with a shutoff and quick disconnect fitting installed. Connect the hoes from the grill to the supply, and fire it up...THIS IS WHAT I INTEND ON DOING TO MY GRILL,BUT YOU DO THIS AT YOUR OWN RISK>>>
May 07, 2009 | Weber Genesis Silver B Grill
I want to convert to natural gas.
The only thing you can do if Weber doesn't have a natural gas manifold for their grills , is to buy one that will fit. They use propane on outside grills because of the stability of the gas. Natural gas will blow out much easier.
Feb 25, 2009 | Weber Genesis Silver B Grill
Grilling Logo
82 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
