Computers & Internet Logo
C
Cindy McCabe Posted on Mar 31, 2014
Screen goes black after I plug in Charger
It was working fine, but after i restarted my computer it stopped working. When my charger is not plugged in it works fine, and when I tried it in safe mode the screen did not go black at all.
Pari K
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Apr 27, 2014
Pari K
Contributor
Level 1:
New Friend:
Answers
38
Questions
Helped
5084
Points
49
Did you remember if you had the same luminosity level with and without the power charger?
Maybe a faulty lamp or inverter if its a non led screen
When is safe mode pc works with standard vga driver not your own
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jan 01, 2009
SOURCE: laptop screen goes black ,but when charger is plugged in it works
This particular model of Hp was shipped with a bad inverter. You can check out the link below to another forum with users with the same problem.
http://forums.majorgeeks.com/showthread.php?s=2d48836d2fa4bb298f0d0f8261490630&t=108320&page=2
In order to fix the problem you just need to discount the old inverter and it should work according to what I have read. The link to the manual is listed below.
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Anonymous
  • 3940 Answers
  • Posted on Jan 17, 2009
SOURCE: Dell Laptop Charger, wont charge bat. but keeps computer running.
The center of the connetor for the AC adapter to the system has a very fine wire that is the sensing wire for the battery charger. It ID's the type adapter connected to the system. If the wire is bent or broken, the system cannot ID the adapter and the battery charger will not function.
If the wire is bent or broken, then replace the AC adapter. ALso try a different adapter and see if the issue occurs with it. If the issue happens with more than one adapter or if this adapter functions normmaly on another system, then the motherboard will need to be replaced.
Anonymous
  • Posted on Mar 16, 2009
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on May 07, 2009
Hi there.
In some cases batteries tend to not charge up because one of the cells are damaged or drained to the point that they will not charge at all.
In other cases it can be the power board on the laptop motherboard itself which can have gone faulty, the only way to tell is to obtain another battery (preferably new) and see if it will charge the new one, if it does then you know that the battery is faulty, if it doesn't then you will have to take the laptop into a shop to be looked at.
This is the only way you are going to be able to work out which one of the two is the cause.
Good luck and thanks for using FixYa!!
Rodie
  • 629 Answers
  • Posted on Jan 06, 2012
SOURCE: My computer is dead, plugged into charger, but not charging
not sure if this is still good enough since the post is quite old, but if another charger also does not work, you either need to get a new battery, or get a replacement motherboard. If another battery is also not being charged on your laptop, the motherboard charging mechanism is faulty. one last try before you replace the motherboard is to check for a BIOS update which you can find by going to support.dell.com, go to the drivers page, input your service tag and look for the latest BIOS for your system. be sure to try to install the update with the charger connected and see how it goes.
rodietom
Whenever I plug in my charger, I lose my USB and have to restart my RCA Galileo Pro.
I would just keep one end of your charger plugged into your main device and the other end close to the device. Then, when you need to charge, you can simply plug the adapter end of the charger into a socket. Thank you.
1helpful
2answers
What would cause my screen to go black and then can't reboot 8.1 on dell pc??
If this is a Laptop, remove battery, Plug in charger to PC and then try to reboot. A bad battery will suck all the power from charger and won't allow the computer to have enough power to boot.
2answers
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
31helpful
8answers
Problem with Garmin Nuvi 200
hold the battery icon for 8 seconds, which will take you to the test screen then plug in the charger then exit This works on a nuvi 200w.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
