Question about Sony VAIO Computers & Internet
My laptop works fine when my charger is not plugged in, but when I plug it in my screen goes black. Then if I take it out it works fine again. It was working fine before, but I had to restart it and n
When I plug it in on safe mod the screen does not go black
    Problem Solver:
  • 9 Answers
You need to go to the device manager and then uninstall the adaptor driver and then restart the PC or else try with a different charger.
Posted on Apr 01, 2014
dgrayman919
  • 10 Answers
SOURCE: laptop screen goes black ,but when charger is plugged in it works
This particular model of Hp was shipped with a bad inverter. You can check out the link below to another forum with users with the same problem.
http://forums.majorgeeks.com/showthread.php?s=2d48836d2fa4bb298f0d0f8261490630&t=108320&page=2
In order to fix the problem you just need to discount the old inverter and it should work according to what I have read. The link to the manual is listed below.
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Posted on Jan 01, 2009
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Posted on Mar 16, 2009
Geekman
  • 32281 Answers
SOURCE: lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 31, 2009
Geekman
  • 32281 Answers
SOURCE: Laptop screen goes black, no backlite
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Picture flickering with dim display or appear black.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Posted on May 08, 2009
sabharish
  • 297 Answers
SOURCE: Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Posted on Jun 11, 2009
What would cause my screen to go black and then can't reboot 8.1 on dell pc??
If this is a Laptop, remove battery, Plug in charger to PC and then try to reboot. A bad battery will suck all the power from charger and won't allow the computer to have enough power to boot.
Aug 18, 2014 | Computers & Internet
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
Screen goes black after I plug in Charger
Did you remember if you had the same luminosity level with and without the power charger?
Maybe a faulty lamp or inverter if its a non led screen
When is safe mode pc works with standard vga driver not your own
Mar 31, 2014 | Sony VAIO Computers & Internet
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
Feb 28, 2014 | Acer Aspire 7720 Notebook
My advent 6651 laptop will not work. the battery light is flashing blue and when i press the on off button it lights up then afer a minute it goes off but the screen never loads up
This issue might be with the RAM refixing if the power is fine.
Please rtefix the RAM once.
If the power also goes after 1 sce then please try without battery,If working the issue with battery if not then issue might be with mainboard.
Aug 14, 2009 | Advent Netbook
Black screen after returning from florida
plug in > if charge light comes on and screen black proceed.... if no charge light comes on on laptop your charger's not working
plug into external monitor > if the external monitor works fine with laptop then your LCD is not working, you can look for the Function key (should be bottom left) and the monitor button (probably f7) and switch back and forth... this should tell you if the lcd works or not.
Apr 20, 2009 | Gateway MX6027 PC Notebook
Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Aug 22, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
138 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
