Question about JumpUSA JUGS Baseball Soft Toss Machine
Wont work its been charging for a day but it wont work without the plug.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
It must be broken
Posted on Mar 31, 2014
I am charging my scooter and it is beeping what do i do
Charge without the key on. Make sure your charger is applying power to the scooter. It may have a blown fuse or some other internal problem. If your batteries were totally discharged your charger will not recharge them. You'll have to charge them individually with an automotive style battery charger that is NOT an automatic charger. It may take 3 days continuous charging to recover enough charge before your scooter charger will continue to charge until the batteries are fully charged. If this doesn't work then the batteries will never take a charge nad need to be replaced.
Oct 15, 2014 | Health & Beauty
Why will my ipad not charge and what do I need to do?
try resetting it, power it off completely. If still not working check charger on another device to make sure charger is OK. If it is you will need to have it repaired, new battery or charging circuit or new socket
May 21, 2014 | Tablets & eReaders
Wont charge at all stays deadwont charge
Check the charger is working by using a multimeter to measure the output voltage.
Dec 28, 2013 | Sony Walkman Audio Players & Recorders
Trying to charge battery...red light stays on a while then goes off..turn computer on and it says battery charged..but not doing much..I know it needs 12 hr charge..do I just leave it plugged in with light...
YOU NEED TO GET THE BUTTER OUT LLET HIM ABOU 1DAY OUT THE COPMUTER AND WORK THE COMPUTER WITHOUT PLUG BATTERY AFTER DAY BUT THE BATTERY IN COMPUTER AND POWER WITHOUT PLUG AND CHARGE IF GIVE U EMPTY
Mar 20, 2011 | Sylvania G-Netbook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My laptop wont charge. if i unplug the ac adapter and plug it again it wont charge... how to fix it?
Check for physical damages on the power cord or teh power brick try it as well on a different Laptop if it does the same thing if the adaptor works fine in a different laptop try plugging the adaptor without the battery on the system try unplugging and plugging it back in if it will work properly without the battery then most probably either your battery needs to be replaced or your systems Motherboard....
also you can try updating system BIOS which is risky, check your Manufacturers website or call them for any information about BIOS updates for the system.
Jun 03, 2010 | Computers & Internet
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
Laptop battery wont charge, wont even turn on to charge.
A common trouble is that the solder joints from the power jack to the motherboard can break. This is due to flexing the power plug over time. When this happens the power can't get onto the board at all to run the computer or charge the battery. Sometimes the connections may still work, so you get the intermittent operation you mentioned.
Usually this can be repaired, but it means disassembling the computer to take out the motherboard and resoldering the connections. In some cases, the motherboard can be damaged by heating and arcing from the bad connections and can't be repeaired, but this is pretty rare. A computer shop might be able to do the repair if they get into that level of service.
Jun 01, 2009 | Compaq Presario 700 470024-192 Notebook
Defintely getting power, but not switching on.
There are several possibilities. Let's start with the easiest two. First the battery, take it out and try starting up only with the power supply. Then the memory chips. If a memory chip fails it can cause a no start in IBM's. Take the memory out and try it. Then try it, putting them in one at a time. If these don't work, then I'm afraid your problem lies within. Namingly the power management chip on the motherboard. The pm chip controls the power input, and allows such functions as switching between battery and AC, and battery charging. The pm chip can go without warning, and just because it lights and shows charging doesn't mean this chip hasn't malfunctioned. I've had several IBM's come through my shop that have experienced the same problem you're describing. I've also had them with problems like; it will only power with the battery, won't charge the battery, will charge battery and only run with battery shuts down while charging, only power under AC, etc... all pm chip related issues. Unfortunately, the only solution is motherboard replacement.
Jun 19, 2008 | IBM ThinkPad T40 2373 Notebook
JumpUSA JUGS Baseball Soft Toss Machine Logo
61 people viewed this question
Top JumpUSA Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a JumpUSA Exercise and Fitnes Expert? Answer questions, earn points and help others
