Question about GE Refrigerators
Changed water filter, now no water comes through. What can I do to fix this?
GSF2516XL side by side. Alert came on to change filter. Purchases new one, installed and now no water comes through it.
    Problem Solver:
  • 22 Answers
Did you install the filter all the way, until it seats? There is probably a switch that has to be closed by the filter before the water valve can be opened, thus preventing water from being sprayed inside your refrigerator compartment.
Posted on Apr 19, 2014
SOURCE: water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Posted on Aug 24, 2008
  • 2692 Answers
SOURCE: dirty water line from filter
Attach flexable rubber line from water bottle, like is used for race bicycle riders,or tape up a hose to a water bottle. Turn off valve at water pipe leadign to line to filter. Remove filter. place a pan to catch water under the machine. Attach A small diameter hose to water line where water exits to glass.With machine turned on and your rubber hose attached turn bottle upside down and squeeze while pressign glass lever. Flush through approximate one quare or until water stream is clear. Their is no pumb ofor flow the line preaure is al that moves the water so backflushing is easy.
Posted on Dec 14, 2008
cactus bob
  • 267 Answers
SOURCE: NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Posted on Jan 16, 2009
jvernice
  • 63 Answers
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Posted on Jul 29, 2009
SOURCE: HOW TO TURN OFF THE "CHANGE WATER FILTER LIGHT"
Press light and lock and hold until light blinks release and the light will go out
Posted on Aug 27, 2009
Low water at dispenser
Hello Chuck, thank you for your post!
From the information you have provided you are receiving low water pressure at the dispenser on your Frigidaire refrigerator. This could be due to a dirty or clogged filter and I would check to see when you last replaced it. I have researched model FRS3R5EMB and show the water filter is part number WFCB.
If you have changed your filter within the past six or nine months the low pressure could be due to an obstruction within the water line or an issue within the dispenser. Since it could be anyone of these underlying issues I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. I hope that this information is helpful to you. -Matt
Apr 08, 2016 | Frigidaire FRS3R5EMB Side by Side...
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Water filter wont work
if the water filter is a small open ended type filter it needs to be primed before it is installed.Air will build up inside the water lines and slow the water from coming out
Mar 31, 2014 | GE Refrigerators
Aqua filter making chirping sound
It sounds like a fault in the board, the cheaping sound is like a muffled alert, trying to tell you it's in trouble. Maybe.
Nov 30, 2013 | KitchenAid (KSRD22FKST) Side by Side...
I have a Kenmore side x side. I have changed the water filter and now water is coming from the water spout when water is needed to make ice. Just prior to changing the filter I noticed water coming from...
Sounds like the dual water inlet valve on the back where the water supply is connected, has gone bad and is leaking across to the other side. It may also put water into the ice maker when you use your dispenser.
Jan 13, 2011 | Kenmore 44103 Side by Side Refrigerator
I changed my water filter and now i need to turn out the filter warning light.
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
Please rate me!
Thanks, Sea Breeze
Mar 22, 2010 | Maytag MZD2766GES Side by Side...
Replace filter is on how do i get it off
FILTER
Thanks, Sea Breeze
Jan 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Changed filter water leaking out of ice maker even when shut off
if u have changed the filter and it wasnt letting water though before you changed it, then some foreign material has come out of the filter and has wedged its self under the plunger of the water solenoid holding it open
Apr 28, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Dirty water line from filter
Dec 14, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
