Question about GE Refrigerators
Water filter wont work
GSF2516XL BB
    Problem Solver:
  • 18 Answers
If the water filter is a small open ended type filter it needs to be primed before it is installed.Air will build up inside the water lines and slow the water from coming out
Posted on Apr 28, 2014
Why is it not dispensing water?
Do you have a dual water inlet solenoid valve ? If so one side might be faulity.
Apr 27, 2014 | GE Refrigerators
Gss23qgta bb
Check water cut off then check your water line it may have a kink in it the next thing would be the pump for the water on the back of the frig if you have water dispenser and ice you have two sided pump just because you are getting water does not mean the water is going to the ice compartment. Also unplug and plug your ice maker this may reset it wait 24 hours it can take that long to start working again. .
Changed water filter, now no water comes through. What can I do to fix this?
Did you install the filter all the way, until it seats? There is probably a switch that has to be closed by the filter before the water valve can be opened, thus preventing water from being sprayed inside your refrigerator compartment.
Mar 31, 2014 | GE Refrigerators
Need to replace water filter on ge side by side gss25jeta bb model and need to know what type of filter to replace it with.
Pull the old one out and see what it is. Check you owners manual for proper replacement instructions. If you do not have and owners manual copy and paste the below URL into your address bar.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60514-2.pdf
May 31, 2011 | Refrigerators
How to open the housing on big blue 20 to change filter
The best way to do this is to shut the incoming water supply off. Open the closest cold water faucet to relieve the water pressure. Shut off the outlet valve. You will need a BB wrench. Push the RED pressure relief button on top of filter as you turn clockwise on the wrench. Lubricate the o-ring with silicone lube, clean filter housing and re-install filter. Only tighten housing hand tight.
RJ
Mar 05, 2011 | Culligan 34" Whole House Water Filter...
Witch direction do i unscrew the culligan hd950 to take out filter
Lefty loosey, Righty tighty. If you can't budge it shut off the incoming water, go to the nearest cold water faucet and run until pressure is relieved. Shut off outlet valve, hold the pressure relief valve down while turning to the left with a BB filter wrench. Lubricate o-ring with silicone lube and only tighten by hand.
RJ
Jan 10, 2011 | Culligan Sediment Water Filter Heavy Duty
BB 8900 doesn't work after falling in water
Try talking to someone at www.bbmedic.com They're good.
Dec 20, 2009 | RIM BlackBerry ® 8830 Cellular Phone
ICEMAKER /WATER
The line in the back of the freezer section is froze up. Remove the ice-maker and use a heat gun or hair dryer to thaw. be careful not to put the heat gun or dryer to close. It wont take long to thaw. BB
Dec 15, 2009 | GE Refrigerators
I have a GE refridgerator model number GSS25IFRE BB the ice maker and water dispensor just stopped working. The filter is new. and still has the problem with the plug in. Also if you hold a glass in the...
Do you have water getting to the filter? if not:first loosen filter and see if you might have air in line,secondly, the copper or aluminum water line from water supply to solenoid may be limed-up,third loosen line at solenoid and see if your getting water that far,those solenoids pulsate when operated on A.C.current you should hear a hum when activated to get water and that would explain pulsating light at water dispenser
Jul 24, 2009 | Refrigerators
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
