Question about Siemens Washing Machines
Siwamat xb 1060
No power, supply and fuse ok.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Could be the transformer inside the machine..
Posted on Mar 31, 2014
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
SOURCE: I have a broken door
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Posted on Jan 09, 2013
No tai lights or dash lights in 2004 Scion xB fuses good no power at rear plugs. Brake and blinkers do work. So frustrated.
Did you look at a wiring diagram to see what all is involved in those circuit's ? The fuse is GOOD ? 10 amp tail lamp fuse is good , but is there Battery + voltage there ? With a volt meter or test light check for B+ voltage on both sides of the fuse . Both the dash and tail lights get B+ voltage from the head lamp switch . You can find a wiring diagram here http://www.bbbind.com/free_tsb.html How to Use Multimeter to Troubleshoot Common Problems
Feb 17, 2017 | 2004 Scion xB
Where is the lighter fuse on a Scion xB 2008
Check you drivers manual it will show where the fuse is located and give the correct fuse to replace.
Posted on Dec 03, 2015
Feb 26, 2015 | 2008 Scion Xb
SCION Xb 2008,I WAS installing a radio and now i have no power coming from ignition key or radio or windows
Hate to state the obvious, but have you checked fuses and fuseable links? Was neg. bat. term. disconnected when you were working on this? Reconnected?
May 11, 2014 | 2008 Scion Xb
Siwamat xli1240
Unplug it for a minute, that should reset it, if that does not work, then you need to get a meter to check the heating coil and also the water valves to see if they are ok.
Nov 11, 2013 | Washing Machines
RF214LXTS 0 I have a whirlpool stove, have power on both incoming legs. the top works fine, but the bake and broil elements in the oven dont work. the saftey fuse on the back seems to ohm out good as...
The way power typically is supplied to the bake/broil elements is that directly off the terminal block 120volts ac is supplied directly to the elements at all times and when the touch pad is pushed a relay on the clock/eoc (electronic oven control) will close and supply 120vac so the element has 240vac to heat. you should be able to see the wire coming directly off the terminal block where the cord from the house wireing connects to,going directly to the elements and as stated above theother 120 vac from the relay to the elements (their is 2 relays,one for bake and one for broil)
As far as testing the oven sensor(temp probe) at room temp the ohms reading should be 1060-1100 ohms and as the tempature rise the ohms rise so to test it verify is 1060-1100 at room temp then heating it usinga blow dryer,match or cigarette lighter and the ohms should rise as it gets hotter and drop when its cooling
Good luck,i hope this helps and if it does help please give me 4 thumbs up
Gene
Jul 27, 2011 | Whirlpool Ovens
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
Mar 19, 2011 | Siemens Washing Machines
My driver side window switch stop working scion xb 08
my xb scion 2005 back window wont work cod it be the fuse where is it.
Jul 09, 2009 | 2008 Scion Xb
My siemens washer will not pump the water out or spin
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
310 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
