Question about Apple iPhone Smartphone
Lights up than turns off - Apple iPhone Smartphone
  • 49 Answers
Sounds like the battery or the software could be corrupt. If you try turning on when plugged in to the wall or a computer does it come on?
If it still doesn't then the phone needs a hard reset - this can be done by following the steps in this link How to Hard Reset an iPhone
Posted on Apr 17, 2014
1977 GMC crew cab 3/4 ton V8 turn signal problem.
My friend is a part time mechanic he gets his solutions
from www.reliable-store.com
he gets from their every single detailed info, instructions etc. on all vehicles, and manuals like service, repairs, parts, owner's, operations, maintenance etc.
U can get help from there
there is a girl at chat she can help you
Mar 20, 2018 | GMC Cars & Trucks
Turn off abs light
Turning off the abs light is not easy to do even if you dissconned the battery the most comeon proble on a abs light to come on proble be n abs sensor each wheel has on you need to put it on a scanner autozone does it for free good luck hope this was helpful good luck
Oct 02, 2015 | Honda Silverwing 600 ABS Motorcycles
Third eye works no rear signal or brake lights
The high mount brake light gets its own signal from the brake light switch (on the brake pedal). Or at least the wire leaving the brake light switch will splice, one wire to the high mount brake light, and the other for the rear brake lights is routed through the turn signal switch, and coordinated there with the turn signal wires to the rear brake lights. The brake wires and turn signal wires share the same wire, and same filament in the bulbs. It is kind of complicated, but brakes applied with no turn signal, brake light wire goes from brake light switch through the turn switch and out to the bulbs. If brakes applied with turning signal, non blinking brake light wire goes from turn switch to rear light, while the turning signal wire will go through the flasher relay, and then to the rear light to cause blinking.
I hope that makes sense. It appears the problem may be in the turn signal switch for both the turn signals and the rear brake lights.
Mar 14, 2015 | 2007 Dodge Ram 3500 Quad Cab Laramie
How can I turn off the rear parking lights
Normally all parking lights are controlled by the light switch. First turn turn on the parking lights and second turn turns on the head lights.
Are you sure it is not your break lights staying on? if this is your break lights - look at break pedal for break light switch staying on or not adjusted correctly. Does your car battery gets drained from your break lights staying on?
Feb 23, 2015 | 2011 Cadillac SRX
When I turn on lights, the turn signal lights also on at the right side and turen signal doesn't act flash
Turn the parking light and compare the brightness on all lights. Next turn the flasher and compare the brightness on all light. Some time light bulb like 1157 will be insert the wrong way and short the light to signal. second open the light socket remove the bulb and inspect for burn mark and rust(replace the socket.
Behind the carpet is the ground point, clean and tight the ground.
and last is the combination switch for light and signals.
Good Luck
Jan 17, 2015 | 2000 Toyota Sienna
Interior lights do not turn off when car is turned off
have you set the light switch to the courtesy light position , with the ignition on turn light switch so light is on then turn switch so light is off ,open door if light comes on that is the courtesy position if does not close door turn switch to the last position then open door light should be on close door light off,TURN IGN OFF EXIT AN LOCK VEHICLE INTERIOR LIGHTS WILL STAY ON FOR A FEW SECONDS THEN SLOWLY DIM .watch them before leaving
Mar 29, 2014 | 2004 Jeep Grand Cherokee
Side lights dont work
Fuse sure didn't play, bulb is unlikely to be all bad. Check the turn signal switch, first find the turn signal switch plug, put the key to ON file, in trying to find a turn signal lamp switch wire (flash to the thread) will this wire with no light ON one side of the turn signal line connected to see if a turn signal light, the light is turn signal switch is broken, or the plug contact undesirable, don't light it is turn signal switch to light ON one side of the light path, in order to determine whether the light bulb is broken can open a small lamp or led brake lights to borrow their wire leads to a turn signal whether turn signal light, so you can determine whether the light bulb not bright side is broken.auto diagnostic tool.
Apr 10, 2013 | 2001 Alfa Romeo 147
Signal lights dont work and want to know where the fog light switch is at
With the switch in sidelight or dip
position, pull the switch to its first
position to turn on the front fog lights.
Pushing the switch in or turning it to OFF
or AUTO will turn off the front fog lights (this is for the front)
With the switch in any position except
OFF or AUTO, pull the switch to its
second position to turn on the rear fog
lights. This will also turn on the front fog
lights unless main beam is selected.
or AUTO will turn off the rear fog lights (this is for the rear)
Exterior lighting
Exterior lighting switch
A. OFF.
B. Side (parking) lights.
C. Headlights.
D. Auto.
E. Front fog lights.
F. Rear fog lights.
It is the round knob nest to the steering colume
Aug 18, 2011 | 2003 Jaguar X-Type
I have no signals and when brakes lights are on, lose brake light to either side turn signal is set on
Hi!!
If you activate the turn signal switch and you step on the brake pedal, the turn switch (on the steering column) deactivates the brake light to make the signal light more visible. The bulb for the stop and turn lights is the same.
Turn hazard lights ON. If they don't blink, replace turn/hazard flasher, If one or more lights don't come on, replace bulb.
Check fuse and circuit wiring for broken or loose connections. If all looks fine, check following:
If front turn lights work fine, check brake/turn bulbs.
If turn lights come on but don't blink, replace turn signal/hazard flasher.
If front and back turn lights don't come on, replace switch on column.
Let me know how it worked out, Good Luck
Mar 24, 2010 | 1991 Plymouth Acclaim
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
