Question about Akai Mpc1000 Music Production Center
Mpc 1000 loud static
MPC keeps making a loud static noise WAY louder than what's being worked on. It sounds like white noise from a TV. Any ideas to what could be wrong?
    Problem Solver:
  • 13 Answers
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Posted on Jun 04, 2014
  • Producevalue Jun 04, 2014
    INTERNAL master level.. possibly.
  • 29 Answers
SOURCE: how to connect my turntables to my mpc 1000
If your turntables use ceramic cartridges, you'll need to use a passive interface box that converts the unbalanced ( RCA ) plugs from the turntable to balanced ( 1/4" T-R-S ) plugs to connect to your MPC1000's stereo line inputs. If your turntables have magnetic cartridges, you will need an active phone preamp, check the music retailers catalogs or on-line there are many makes and models.
If you want to mix the two turntables ( sequeing from one to the other and back continuously as in a DJ setup ), you'll need a small DJ mixer.
Hope this helps.
Posted on May 15, 2009
  • 1137 Answers
SOURCE: mpc 1000 beginner
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
Posted on Jan 21, 2010
  • 1137 Answers
SOURCE: os update promblems mpc 2500
Try this site:http://www.akaipro.com/mpc2500 Try downloading all the the release notes for ver.1.24 if you haven't already. Download the ver.1.24 which seems to be the newest to your computer first and install from there. It might have gotten corrupted the first time you tried it. You will have to email them using the form for the newest release notes and the installation instructions:http://www.akaipro.com/mpc2500 http://www.akaipro.com/content1924.html and http://www.akaipro.com/mpc2500 are the URLs you need. Hope this helps.
Posted on Apr 16, 2010
  • 5603 Answers
SOURCE: I have an older MPC 1000 & just today it
There is probably a switch problem. IF these use the conductive rubber contact type switch buttons where a "pill" of conductive rubber is pressed onto a circuit board with traces, CLEAN the contact rubber AND the circuit board with 99% isoprophyl alcohol and Q tips. This type buttons feel "Rubbery and squishy" when pressed.
If the buttons have a hard tactile feel, then check for a bad button that might have broken internal parts and replace it... OFTEN you can tell by the "feel" when pressing compared to others.
In either case, disassembly and service is required.
Posted on May 14, 2010
SOURCE: My mode button on MPC 1000 broke... can't find replacement part
mpcstuff.com vstservice.com hiphoptools.com
Posted on Sep 04, 2010
White Noise
well believe it or not. a wood block is not a bad idea. ive done it myself. it is non conductive, so you won't short anything out. to answer your question, a circuit board is layed out in several levels. not just what you see on the surface. so your problem could be internal on that particular board . So when you bend it, it then makes the connection it is suppose to. Weather it be a ground or it completes a circuit. You can use the board method , or contact the mfr and purchase a new board. Which if you choose to do that, know that handling and installing that board , you want to make sure you release any static electricity from your body before doing so. You don't want to short out the board before you get a chance to see it work.
Apr 03, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
Static crackling sounds
Replace the speakers or let it be repaired by some one.their may be rust near the speaker coils.just giv it a try.
Nov 20, 2013 | Yamaha Music
When using the DM-4800 I hear a loud hissing/buzzing/digital sound. I suspect it to be a clocking problem. Everything is functioning normally until i push up any of the faders. when i do this, it results...
Just make sure that your input levels are adequate. Some digital noise will occur if signal levels are so low that they are using only a few bits of the dynamic range of the digital numbers of the unit. The idea is to have the gains balanced througout so that all signals are in the normal operating range. Make sure any UNUSED or undriven channels are MUTED. Open circuit inputs MAY have significant noise... this is a statistical thing that has a minimum level dictated by the laws of physics.
Sep 06, 2011 | Tascam DM-4800 Mixer
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
On more than one occasion my x2442usb, makes a loud static like sound coming from no apparent individual channel but its just there. is this a flaw in the mixer should i send it back?
First, make sure ALL interconnected equipment is POWERED from the same receptacle.
Second, if the sound is routed through your computer via USB, make sure ALL background programs like wireless internet connection, anti-virus, anti-spyware, popup blockers are DISABLED.
These system hogging programs can interrupt the flow of the sound data causing static like noise.
Also use balanced lines for ALL audio interconnects... eithe XLR or TRS cables.
Dec 17, 2010 | Behringer Xenyx X2442USB / Harbinger...
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
I have an older mpc 1000 & just today it started changing the programs & number of bars of the sequence I was making when I pushed the cursor.
May 12, 2010 | Akai Mpc1000 Music Production Center
Akai Mpc1000 Music Production Center Logo
185 people viewed this question
Top Akai Music Experts
T-Comtech Repairs
T-Comtech Repairs
ray gallant
Are you an Akai Music Expert? Answer questions, earn points and help others
