Question about General Electric GFWH1400DWW Front Load Washer
GE front load washer door is locked says so on LED But No other lights on,Unluged it waited ,nothing has water inside a third full ,just hums so unpluged again,cleaned filter trap,nothing??
Does not drain water out,filter is clear
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Water punp could be bad.
Posted on Mar 31, 2014
scottowa
  • 87 Answers
SOURCE: push start different sound water may start may not start pause
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
Posted on Mar 04, 2009
SOURCE: Front loading ge washer won't drain?
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
Posted on Jun 04, 2009
  • 9 Answers
SOURCE: GE WSSH300G Front Load Washer drains, but
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
Posted on May 27, 2011
caroldon
  • 17130 Answers
SOURCE: I have a GE adora
is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Thank You for using fixya
Posted on Sep 05, 2011
SOURCE: I have a GE Front
I have a ge elite front load dryer and the door won't stay shut. Is this something simply
Posted on Feb 28, 2013
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
GE model WHDVH626FWW Front load washer won't run, can't open door
your drain pump is likely clogged,and is equipped with a clean out port. remove lower cover by 3 phillips screws on bottom front. you see the drain pump up front to the right. If there is a lot of water left in machine then have bucket/pan avail and plenty of towels. wet dry shop vac helps. you can open door and remove clothes from here. reach up on right side to where the latch is on inside (you have to go by feel) and find small round pull tab on bottom of latch/lock asm, and pull down, this will unlock door. carefull of water level when opening door.
to fix problem, unscrew cap on pump asm. water will pour out, and a tray will slide out with debris clogging pump. look inside housing for remaining ****. using finger check impeller area on right..
reassemble. machine should work perfect now. Pump is designed to be cleaned out and will not void warranty. newer machines have access port cut in panel for this clean out area.
Apr 26, 2009 | GE Washing Machines
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Ge adora whdvh626fww not filling with water and locks door
Can you take a look at the pump to see check why it is able to pump-in water ? Motor is still good as you can hear it trying to pump-in water.
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washer will not start and is making a buzzing sound.
did the belt fall off in the back of the washer. Mine was overlaoded and the belt came off somehow- it went back on fine.
Apr 17, 2008 | GE WSXH208A Front Load Washer
General Electric GFWH1400DWW Front Load Washer Logo
87 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
