Blinking lights (all 3) after replacing an original HP 310 black ink on my HP Desktop 2540 printer
Before I replaced cartridge only one light blinked, after all 3 blinked! Does not want to print nor copy
  • Mazliza Cumming
    Mazliza Cumming Mar 31, 2014
    Sorted it all out myself! Read the manual to find out what those lights mean! It turned out I didn't close the printer flap/door after I replaced the ink! Door shut, lights off n printer works again! praise The Lord!
    Champion:
  • 241 Answers
Just celaning contacts of cartridge and try again
Posted on Mar 31, 2014
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
Mar 01, 2014 | HP DesignJet 450c InkJet Printer
Hp 2410 psc all in one has all lights blinking does this indicate that I neeed new cartridge It tells me to remove the right cartridge and then replace it
yes maybe it require to replace the cartridge, but before doing it pls insert the cartridge one by one, i mean put the black ink then observe if the light stop blinking,if yes then the color ink need to replace
Oct 27, 2011 | HP PSC 2410 All-In-One InkJet Printer
Full ink catridge but light is still blinking.
The light blinking when the ink cartridge is failed.Left lamp is for color cartridge failed, right is for black cartridge failed.Try replace it.
Nov 12, 2009 | HP DeskJet 5150 InkJet Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
My HP printer's light blinks, but it doesn't print.
two things to consider.
1. If the blinking is fast (like more than two blinks per second) then the printer is damaged. Either the main controller board is fried or the carriage/ink controller is damaged.
2. if the blinking is slow ( 1 blink per second) this means that either of your cartridges is busted. remove the black cartridge then close the top cover. If the blinking stops, then the black ink is the culprit. If not, replace the black then remove the other cartridge. THis means that one of your cartridge needs to be replaced.
Sep 27, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
24 people viewed this question
jasbo
jasbo
