Question about Fisher and Paykel GWL11 Top Load Washer
Power switch does not activate
When I press the power switch nothing happens. There is power to the outlet. The washer is plugged in. The switch appears to be broken. Does this mean I should replace the washer control panel or the washer display board?
  • 5 more comments
  • garythomas66 Mar 31, 2014
    Out of balance switch, reach in between the body and the bowl at right rear and you will find a plastic arm hanging down GENTLY wriggle the arm back and forth then try your machine again.
  • Kim Marhoefer Willis
    Kim Marhoefer Willis Apr 01, 2014
    The power switch does not engage. Is that somehow connected to the "out of balance" switch?
  • Paul P Apr 01, 2014
    If absolutely nothing happens when power button is pushed usually means the main fuse inside the motor control module has popped for some reason. Ususally requires the replacement of the motor control module. GWL11 is called a "Phase 6" type module which is brown in colour. Before fitting the module you must check the pump and stator resistance readings by somebody who knows how to use a multimeter. Hope this helps.
    Me again. I forgot to add this
    Sorry about this but everytime I push enter this writing gets posted. check page 3 of this website under "Phase 5" for the readings http://www.angelsnz.net/ZL3SV/misc/F&P%2... and page 9 of this site for motor controller parts number http://www.angelsnz.net/ZL3SV/misc/F&P%2...
    The first website should be ......... http://www.angelsnz.net/ZL3SV/misc/F&P%2...
  • Fisher and P... Expert
  • 554 Answers
Your motor controller board could be faulty.
Posted on Apr 21, 2014
  • 351 Answers
SOURCE: no power
it sound like the lower board has failed check that ther was no water leaks from the valves into the board also check that the resistance on the valves are the same if they are diffrent this can blow the board as well. hope this helps.
Posted on Mar 07, 2008
  • 713 Answers
SOURCE: no power
possible faulty module. did u check fuse on circult board? water proberly coming from faulty water valve.u need 2 find where water is coming from b4 u install repaired circuit board.please reply 4 more help
Posted on Apr 08, 2010
  • 713 Answers
SOURCE: lightning hit house. power to washer nothing works
glad to help. it makes me feel guilty when i do a pensioners machine and they clearly don"t have much money. so i always charge them cost price for the part and give them a pensioners discount. it"s always good to make someones day. please reply if you need any more help. god luck and bye for now.
Posted on May 19, 2010
Testimonial: "Very helpfull and was integral in solving the problem."
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
  • 713 Answers
SOURCE: drain pump and motor control board was replaced.
Hi just read your posting.Sorry to ask these questions but why did you replace the control module and pump?When you turn the power off then on at the wall does your machine light up the display and give a beep as well? Did you hear a popping sound when you tried to use the machine?Did you smell anything burning?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 20, 2010
Roper washer don't start
That is still under warranty, you have done all that you can within reasons. Call Lowes.
Jan 24, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
one place you say 2013 then it is 2014 then later 2017. we can not assist you when even you do not know what it doesn't do oneplace it is admiral , then a roper call LOwes
Mar 01, 2017 | Admiral 3.4 cu. ft. Top Load Washer in...
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Will not turn on
# 1 reason for service call is the machine is not plugged in. Make sure outlet has power and washer really is plugged in. If not, then something inside is bad and needs to be taken apart. If absolutely nothing happens, then switch is bad.
May 26, 2009 | Maytag Washing Machines
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Sharp AR-336 copier was moved, now it will not power on
no, its possible you blew an internal fuse in the machine. only one power switch.
Jan 22, 2009 | Office Equipment & Supplies
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
51 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
