Question about Dell XPS Computers & Internet
Problem with dell xps computer
Need to remove the fromt cover of a dell xps computer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
There is at back some screws you can take back off
Posted on Mar 31, 2014
Theater lightning batteries?
Battery compartment is on the rectangular case attached to the sides of the hard drive units, you need to remove the screws on the cover to remove it then replace the batteries inside if needed.
Dec 27, 2013 | Dell XPS 730X Desktop Computer
How do I change the battery?
on the bottom of the computer, use this pic to remove and replace.3_8_2013_3_37_59_am.jpg
Mar 08, 2013 | Dell XPS M1210 Notebook
Dell xps beep hard drive not found
The hard drive may be malfunctioning, remove hardware and reseat back in place, if no change have it checked for possible replacement.
Oct 26, 2012 | Dell XPS 15z Computer Intel Core i72620M...
How to change the keyboard on dell studio xps 1645
You have to remove the palm rest ( the top part that has the keyboard and touch pad) to access the 13 screws securing the keyboard and shield which are underneath the palm rest. This involves removing the bottom access cover, rear caps, remove ten screws that are marked with a small P on base of computer. Remove two screws that are marked with a K. Remove two flat-head screws in the battery compartment. Then flip the system over. Remove the two screws at the top of the palm rest. Pry the palm rest loose with your fingertips, starting at one edge. Flip open the latch on the keyboard ribbon cable connector, and remove the cable. Lift the latch on the touchpad ribbon cable connector, and remove the cable. Remove the palm rest.
Feb 15, 2011 | Dell Studio XPS 1645 Laptop
How do I open the cpu
at the backside of the cpu you can find the screw remove that slide your cabinet your cpu will open
Jun 29, 2010 | Dell XPS 600 PC Desktop
My Dell XPS 400 PC will not Boot up past the "System password"
Both the system password and the BIOS password are set in the BIOS CMOS. You need to clear the CMOS.
The online Dell service manual for the XPS 400 provides a clear and detailed procedure for clearing the CMOS. It's just a matter of moving some jumpers around:
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
If you are not used to working inside computers, start with "Removing the computer cover", then go to "System Setup" and click on "Clearing Forgotten Passwords".
Another method is to unplug the power cord and remove the CMOS battery for a 1/2 hour or so. For details on how to do that, try this website:
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
May 22, 2010 | Dell XPS 400 PC Desktop
Need to unlock a Dell XPS M1530
Turn the computer off.
Remove the battery.
Disconnect the AC adapter.
Reconnect the battery.
Turn it on, and it should be "unlocked".
If not, tell us what error-message(s) are displayed.
Dec 13, 2009 | Dell Computers & Internet
How to remove xps 630 cover non latch side
The rest of the chassis should be a solid piece, I don't think the other side is removable. Below is a link that shows how to remove any component in the XPS 630 System.
http://support.dell.com/support/edocs/systems/xps630i/en/SM/HTML/index.htm
Dec 01, 2009 | Dell Computers & Internet
I need to replace the power button cover on the dell xps m1530which i have here in front of me
easy....
Take out the battery... there will be two screws under it... take them out. You will see two "notches" where a small flat head may fit, put one in and gently seperate the "media cover" from the other plastic just a little bit.
Flip the laptop over. Now the "media cover"(with your power button) will come off. Pull up from the right side carefully, there should be a ribbon cable holding the media cover to the motherboard. To get to it you must unscrew and remove the keyboard.. it should be held in by two screws. carefully release the ribbon cable from the motherboard.
Good Luck.
Sep 08, 2009 | Dell XPS M1530 Laptop
Dell XPS ONE desktop
if you do this do not tell dell xps support that you did. remove the back cover. you will see two slots for memory. goto your local bestbuy or dell.com and get 2 2gb sticks of the same speed. install memory and replace rear cover.
Sep 15, 2008 | Dell XPS One All-in-One TV Desktop with...
Computers & Internet Logo
Alun Cox
