The black part you mention is the drain pump motor. If the pump impeller is damaged, the motor may still run, but the pump will not drain any water. If the washer does not drain, it will not go into the final spin. The pump is sold as an entire assembly. Go to searspartsdirect.com and type in your COMPLETE model number. The pump will be listed under the "Pump and Motor Parts" heading as item number 10 (part #280187). This is not a standard part that an appliance repair center would normally carry in their inventory, so it would have to be ordered anyway. So...why not cut out the middle man? You can use other web sites for a cost comparison, but this is the cheapest place I have found it listed (use the part number listed above for your search)
If you need instructionson how to replace the pump, you can use this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
