Question about Motorsports
Oil pan: gasket or RTV?
Hanes manual says RTV box says gasket. Which is better?
    Problem Solver:
  • 9 Answers
Use (apply) a silicon gasket compound on the oil pan gasket surface, mount the gasket to the oil pan and then mount the pan to the engine block. Permatex works well in this application.
Posted on May 07, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 176 Answers
The gasket is beter also cek the service manual to see the replacing oil pan
Posted on Mar 31, 2014
Instructions on removing an oil pan to replace gasket on a 1995 saturn SL1
  1. Raise the front of the vehicle and support it safely using jackstands. Remove the plug and drain the engine oil from the pan and crankcase.
  2. Disconnect the fasteners from the exhaust manifold flange and the pipe rear flange, then remove the front exhaust pipe and gaskets from the vehicle.
  3. Remove the engine stiffening bracket and the flywheel cover.
  4. Remove the right wheel and splash shield, then loosen the 4 front motor mount bolts. Back the bolts out about 1 / 2 in. (12mm).
  5. Remove all the oil pan bolts. For vehicles with a manual transaxle, an 8mm flex socket may be used to access the rear oil pan bolts located next to the flywheel.
  6. Using SA9123E, or an equivalent RTV cutter tool, separate the oil pan from the engine. Drive the tool around the pan to shear the RTV seam, then tap the pan sideways with a rubber mallet to loosen.
  7. Pry the engine mount away from the engine as necessary and remove the oil pan. Be careful not to damage or score component surfaces when prying.
To install:
  1. Carefully clean the gasket mating surfaces with a scraper and solvent.
  2. Apply a 0.16 in. (4mm) bead of RTV sealer to the pan flange. Make sure the RTV is applied to the inner side of the flange from the bolt holes as shown.
  3. Install the oil pan within 3 minutes of RTV application and tighten the bolts to 80 inch lbs. (9 Nm).
  4. Tighten the front mount bolts to 37 ft. lbs. (50 Nm).
  5. Install the right splash shield and wheel.
  6. Install the engine stiffening bracket and the flywheel cover.
  7. Install the exhaust pipe. Tighten the pipe to manifold nuts in a crosswise pattern to 23 ft. lbs. (31 Nm) and the pipe to converter bolts to 33 ft. lbs. (45 Nm).
  8. Remove the jackstands and carefully lower the vehicle, then fill the engine crankcase with clean engine oil immediately in order to prevent an attempt to start the engine without oil.
  9. Start the engine and check for leaks.
May 19, 2011 | Saturn SL1 Cars & Trucks
How to replace oil pan gasket?
Very easy,dirty,messy, job. Grab few item from auto zone. Such as rtv sealant gasket itself, a blade or something to remove the old gasket. 4-8 quarts of oil 10w40 synthetic. Oil filter oil filter remover socket set. Run car for 5 minutes. Drain oils. Recycle it... Dart removing the screws around the oil pan. Once remove clean the surface remove the old gasket with shart razor blade make sure do not damage the surface where the gasket go. The gasket go between the oil pan and the engine mating surface . Clean the pan and clear as much gunk you can out the pump opening or tube. put rtv sealant ( some don't need the gasket because they r the gasket.) place gasket putt screw back it. Change filter refill the car with oil ( 4-8 depending on engine size) That's it.
Dec 29, 2010 | 1999 Ford Taurus
How do you replace a gasket and cover for timing chain and rear seal gasket for oil pan on a 1978 Chevy 350 motor
the oil pan will need to be removed to repalce the rear seal, so replace the front seal and gasket then, replace the timing chain/gears if sloppy, then reinstall the oil pan.
Dec 11, 2010 | Chevrolet Blazer Cars & Trucks
How do i remove the oil pan
REMOVAL & INSTALLATION - Oil Pan
CAUTION The EPA warns that prolonged contact with used engine oil may cause a number of skin disorders, including cancer! You should make every effort to minimize your exposure to used engine oil. Protective gloves should be worn when changing the oil. Wash your hands and any other exposed skin areas as soon as possible after exposure to used engine oil. Soap and water, or waterless hand cleaner should be used. (except 2.5 Premier engine)
Fig. Fig. 1: Exploded view of the lubrication system for all 2.2L and 2.5L except Premier engines
Fig. Fig. 7: Apply sealant to the ends of the new oil pan end seals at the junction of the cylinder block pan rail gasket-1988-95 2.2L and 2.5L except Premier engines
Fig. 8: Clean the gasket mating surface of the oil pan of all old gasket material, dirt, grease or other grime-2.6L engine
  1. Apply the parking brake, block the rear wheels, then raise and safely support the front of the vehicle on jackstands.
  2. Drain the engine oil. This would also be a good time to change the oil filter.
  3. Remove the engine-to-transaxle struts, if so equipped. These struts prohibit access to the oil pan mounting bolts.
  4. Remove the torque converter or clutch inspection cover.
  5. Support the oil pan and remove the mounting bolts.
  6. Lower the pan and remove the old gasket, if so equipped.
To install:
  1. Clean all gasket surfaces thoroughly.
  2. For 2.6L engines, position a new gasket on the oil pan using a sealer to hold it in place.
1981-87 2.2 and 2.5 Liter engine uses a liquid form-in-place type gasket. Chrysler Part Number 4205918, or equivalent RTV gasket material must be used.
  1. For 1981-87 2.2 and 2.5L engines, install new end seals and apply the form-in-place gasket sealant. The RTV gasket material should be applied in a continuous bead approximately 1 / 8 in. (3mm) in diameter. All mounting holes must be circled. Uncured RTV may be removed with a rag. The oil pan should be tightened in place while the RTV is still wet to the touch (within 10 minutes). The usage of a locating dowel is recommended during assembly to prevent smearing of the material off location. Make sure to apply sealer where the end seals meet the block.
1988-95 2.2L and 2.5L engines utilize end seals and side gaskets, not liquid gasket as with 1981-87 models.
  1. On 1988-95 2.2L and 2.5L engines, install new end seals and side gaskets. Apply RTV sealant to the parting lines between the end and side seals on these engines. If necessary, use a little grease or RTV sealant to hold the side seals in place.
  2. Tighten the pan bolts in a crisscross fashion, starting from the center of the oil pan and working toward the ends, to the following torque values:
    2.6L engine-53-61 inch lbs. (5.9-6.8 Nm) 1981-87 2.2L and 2.5L engines-16 ft. lbs. (22 Nm) 1988-95 2.2L and 2.5L engines-M8 bolts, 16 ft. lbs. (22 Nm); M6 bolt, 105 inch lbs. (12 Nm)
  3. Allow the oil pan to sit for 15 minutes to ensure that the RTV sealant has completely set.
  4. Install the oil drain plug and a new oil filter, if equipped, then lower the vehicle.
  5. Refill the engine with oil
  6. Start the engine and check for oil leaks.
Hope helps (remember rated this).
Aug 12, 2010 | 1987 Chrysler LeBaron
What is the proper procedure to changing an oil pan and can i use an RTV sealer instead of a gasket?
I would suspect that this is an Escort style pan in which RTV is the oil pan gasket. I have always applied a thin layer of RTV to the pan and the block of the engine, allow them to dry for 1/2 hour, then reapply a second thing layer to the oil pan and install. I have never had one leak after using this method. Make sure that the bolt holes stay open during this whole process.
Aug 03, 2010 | Ford ZX2 Cars & Trucks
Oil pan gasket leaks. It has been changed 2 times and now I am told that it doesn't take a regular gasket, but liquid gasket that is put on the oil pan. Is this true?
Yes this is true. I have always applied the RTV to the oil pan first in a liberal layer and then allowed to set up then applied a second layer and installed pan. Never had one leak after that.
Typically these are assembled wet (not set up) by the inexperienced. This allows most of the RTV to escape between the surfaces.
Jan 19, 2010 | 2003 Nissan Altima
Do i need to drop the oil pan to ghange the timing cover gasket on a 95 ford mustang v6?
You can pull the motor mounts bolts and jack the motor up alittle, that will give you enough clearance to drop your oil pan. If you try and replace the timing chain cover without dropping the oil pan, you will more than likely wind up with an oil leak.
You should be able to replace the timing cover without removing the oil pan. The gasket set should contain gaskets allowing you to cut the oil pan gasket and put in a new partial gasket in this area. In the corners make sure you use some RTV sealant. If you are careful, it can be done. Like Bob A says you can end up with a oil leak without dropping the pan (unless you clean up the area and properly apply the RTV and gasket). If you have time to drop the oil pan, then I would do that.
Oct 21, 2009 | 1995 Ford Mustang
2001 Silverado oil pan gasket is it hard to change?
it can be you must remove oil filterand housing along with oil cooler lines lower trans lines you really need a repair manual for this kind of repair for torque specs and procedures
Jul 10, 2009 | 2001 Chevrolet Silverado 2500HD
86 cj oil pan gaket replacement
http://www.scribd.com/doc/6274603/jeep-cj-19491986-repair-manual
Sep 14, 2008 | 1986 Jeep CJ7
Motorsports Logo
228 people viewed this question
Top Motorsports Experts
Steve P
Steve P
Jim Rus
Jim Rus
chuck ringwood
chuck ringwood
Are you a Motorsport Expert? Answer questions, earn points and help others
