Question about Westinghouse 32" Flat Panel LCD HDTV
My tv when powered on, only show the westinghouse logo and then the screen turn black in about 3/4 seconds
The sound however, is audible and the little blue indicator light still is also on.
  • Westinghouse Master
  • 3,320 Answers
The TV is not receiving a video signal. It is probably the cable you are connecting the tv to the source. If you are using an adapter, don't. Buy a proper cable.
Posted on Mar 31, 2014
Tv screen goes black ater 10 seconds
there could be several things causing this, most often it's a defective inverter, or a bad CCFL lamp. You could also have a problem with 24vdc output from the power supply, or "backlight on circuit from the main board. Get a proper diagnoses.
Sep 08, 2012 | Westinghouse TX-47F430S 47 in. LCD TV
Screen go back to black after the westinghouse logo displays.
Westinghouse? A model number might help me help you---does sound remain or never make it on?
Mar 14, 2012 | Televison & Video
I have a Westinghouse W3223 TV which has decided not to turn on any more. It powers up just fine as always. But instead of showing the video input source before showing the picture, now it shows nothing...
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 25, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse SK 32H540S when i Turn on TV, get Westinghouse logo, picuture turn on for 2 sec then black screen.
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
May 27, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse SK 32H540S Turn on TV, get Westinghouse logo, picuture turn on for 10 sec then black screen.
Hello, it sounds like you need to replace the inverter board, I believe this model has LIPS board which is the power board and the inverter board put in to one single board. You can find price and availability for parts by emailing parts@wde.com.
Feb 02, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Westinghouse LCD TV that is 1.5 years old. When I turn on the TV the Westinghouse W shows up then the picture will show up for about 3 seconds then go to a black screen. The sound is normal.
I'm willing to bet it's the main board. Its the board that all the video and audio inputs. What is the model number I could find the part for you. You could change it out yourself, Its not that hard. Let me know.
Dec 15, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a Westinghouse TV , when turned on the Westinghouse symbol W comes up but no picture or sound and then it turns black. The light stays a solid orange. what can i do to fix my t.v
I just fixed the same model and with your symptom. What it appears to be is the main module is locking up just after the Logo goes away. All you can do is unplug and try again and all you will get is the logo for 5 seconds and then black screen, no sound and led stays lit. Cannot turn off or on. The power supply is actually working fine, it's the main module that has died. This module is no longer available, the part number was W470PROLX68. What i did to restore operation on this unit was to insert 3 volts into the plug going to the master inverter board and then plugged the tv AC cord in. The set showed the logo and then it started working. I removed the 3 volts and it has worked every time since then.
Here is what you should try to do: First take two AA batteries and solder them in series and attach two short wires so you can use it as a power source. Now you have a 3 volts power supply. Next Remove the stand first before removing the back cover. Looking at the back of the unit you will see the power supply and the main circuit boards in the middle (under metal shields) and two boards on each side. These are partially covered with a metal shield, the one on the left side is the master inverter, the one on the right is the slave inv. They both have a plug and wires going to them from the power supply, but the one to the master will have two extra wires. I believe the colors are purple and blue, and they are separated with an empty hole (unused part of the plug). The wire on the end is where you will hook up the positive lead of your battery pack. The negative lead simply goes to the metal shield. With these hooked up plug the tv into the ac and give it a couple seconds and hopfully you will see the tv come on. If it does then disconnect the battery pack and try it without it. good luck.
Sep 25, 2009 | Westinghouse TX-42F430S Television
Westinghouse SK32H240S TV will not show picture...
Some solutions to this same problem were posted here, hope this helps.
Nov 22, 2008 | Westinghouse SK-32H240S Television
Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
Oct 22, 2008 | Westinghouse LTV-46w1 HD 46 in. LCD...
Westinghouse 32" Flat Panel LCD HDTV Logo
135 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
