Russound ca4-kt1 no sound
Any advise on why i wont have any sound on this system keypads is all on devices is wired all anologue
    Champion:
    Habit-Forming:
  • 210 Answers
Does the system have its own speakers? I understood that sound system required speakers to be attached. Check that you put the right model up.
Elisa Jed ' http://www.fordtronicvideo.net.au/about-fvs.html
Posted on Jun 11, 2014
Why won't my Roussand R850MC amplifier play sounds into our multi-room setup?
Sounds like one of the power amplifiers in your Russound has a short. It's not a difficult repair for a good technician. Try a local stereo shop or send it off to Russound.
Dec 21, 2014 | Audio Players & Recorders
"russound x75" + "no power"
Check the power cord with a multimeter for continuity of the wire.Check the fuse unit of the device ,and the soldering points for dry soldering
Aug 31, 2014 | Russound X75 Amplifier
Russound smart media server
What is the problem you faces with this device? Provide more details, please.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 07, 2014 | Russound Sms-3 Smart Media Server 250gb
Russound x75 stopped working wont power on
Check the fuse! Is it plugged in? Is it turned on. Have you read the manual?
Jun 27, 2014 | Russound X75 Amplifier
I have a russound tch1 and since the ios 7 upgrade its not working.
Just saw this on fixya - if you still have the system I would recommend going to Russound.com Support under integration to download the updated firmware for the TCH1 or look into the new perkins innovation unit that supports the new My Russound App
Oct 19, 2013 | Russound Computers & Internet
When it says 'no controller' on CAM6.6T what do i need to do to fix it?
Have you called the installer that put the system in? No Controller means exactly what it says: the keypad powered up and it doesn't see the controller (CAM6.6). This can be caused by a short or break in the Blue pair of the CAT5, the punch down on the back of the keypad or the RJ45 connected to the port on the back of the CAM is loose. Should be easy to troubleshoot for someone familiar with the installation of the system.
Mar 31, 2013 | Russound Cam6.6t 6 Zone 6 Source...
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
Does the Comcast remote work in IR and UHF? Infrared and UHF(able to go thru walls or floors.
Depends on the converter box but chances are yes its has both communications.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | RCA HD52W59 HDTV Projection Television
I have a Russound CAV6.6 Rnet controller. The controller will turn on, but I can get any sound out of the speakers. It used to work just fine. Now the lights come on, but no sound from the speakers. I took...
Have you changed any connections behind the CAV recently? This happened to an associate of mine once and it just turned out to be something simple. This may or may not be the situation in your case. Check to make sure your source audio cables are connected to the correct source number that you assigned in the programming (Ex. AM/FM Tuner = Source 1). Also make sure your audio cable is connected to Source 1 IN (and not the "OUT").
Narrow down the source of the problem:
Make sure the keypad you are using to test the CAV is not in "Mute" mode. Press the "Pause" button to engage/disengage from mute.
To further troubleshoot your issue if the above is not the case you want to use a device (such as an ipod tthat you are sure the audio output is working using a stereo mini to red and white rca cable) and plug into each source input (one at a time) behind the Cav then monitor that source# on the keypad to see if you hear the ipod on any of the sources. If you hear the ipod playing on some sources and not others it obviously means some of your source inputs are having problems and the unit needs to be shipped to Russound for repair.
Make sure the front of the Cav6.6 has the proper colored lights lit up. When no keypads are on the zone should show red, when a keypad is off the color should be green for that zone, if there is a short circuit with the speaker wire the CAV might be in protection mode and the color might show orange.
Hope this helps.
Mar 01, 2009 | Marantz SR-7200 Receiver
 Grubhead
Grubhead
