Question about Russound Audio Players & Recorders
Got no sound on my ca4-kt1 system although keypads is ON
All anologue sources is connected 1-4
Have picture on blue ray but no sound through surround sound system although sound is fine on cable tv
They will use different sound sources for the two functions. It's best to connect a blue-ray to the sound system via an optical lead for the sound. This will transfer the much higher quality sound to your system. If you have the connections in place then it will probably be just a case of making certain you have both the correct output settings for the Blue Ray sound and the correct input settings for the sound on your amp.
Oct 19, 2016 | Audio Players & Recorders
CHANGE CHANNEL TO AV/SCART ON A GOODMANS TVC 1400 WITHOUT THE REMOTE CONTROL , ONLY RUNS THROUGH 7 CHANNELS
Not familiar with this, but see if there is another button on front or top or behind a cover marked AV or source, if so then that will select the channel you want.
Sep 16, 2014 | Televison & Video
Russound ca4-kt1 no sound
Does the system have its own speakers? I understood that sound system required speakers to be attached. Check that you put the right model up.
Elisa Jed ' http://www.fordtronicvideo.net.au/about-fvs.html
Mar 31, 2014 | Audio Players & Recorders
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
Whatever I listen to, the sound comes out of my tv instead of my speakers, although when i checked the speaker volume there working
Free PDF Instruction Manual at the link below.
http://download.p4c.philips.com/files/h/hts3154_05/hts3154_05_dfu_eng.pdf
Check Page 10 Point 2.
b Source buttons
- DISC/USB: toggles between DISC or
USB mode.
RADIO: toggles between FM and AM/
MW band.
TV: switches to TV mode. The sound
from the TV will output through the
connected speaker system.
AUX/DI: switches to the external device
that is connected to the AUDIO IN-AUX
socket.
MP3 LINE-IN: switches to audio device
that is connected to the MP3 LINE-IN
socket.
Apr 17, 2011 | Philips HTS 3154 Theater System
I have a cd changer player Sanyo md cp-1770. connected to my stereo receiver, but no sound coming out, although it shows it is playing, what do you think is going on?
Close, but not EXACTLY a modl lnumber or how it's connected. What output to what input? Is the proper source selected? Does it work withg its onboard FM. Clues, please.
Aug 04, 2010 | Sanyo Audio Players & Recorders
Switch our tv to souround sound
Surround sound will come from the speakers from your surround system. So if you have it connected through HDMI 1 select that option from the source button on the remote control. If you have it connected through Scart 1 then select AV1 from the source button. It also best to turn the volume from the TV to minimum so that the sound only comes from the surround speakers.
Mar 23, 2009 | LG 47LG50 47 in. LCD HDTV
I have a Russound CAV6.6 Rnet controller. The controller will turn on, but I can get any sound out of the speakers. It used to work just fine. Now the lights come on, but no sound from the speakers. I took...
Have you changed any connections behind the CAV recently? This happened to an associate of mine once and it just turned out to be something simple. This may or may not be the situation in your case. Check to make sure your source audio cables are connected to the correct source number that you assigned in the programming (Ex. AM/FM Tuner = Source 1). Also make sure your audio cable is connected to Source 1 IN (and not the "OUT").
Narrow down the source of the problem:
Make sure the keypad you are using to test the CAV is not in "Mute" mode. Press the "Pause" button to engage/disengage from mute.
To further troubleshoot your issue if the above is not the case you want to use a device (such as an ipod tthat you are sure the audio output is working using a stereo mini to red and white rca cable) and plug into each source input (one at a time) behind the Cav then monitor that source# on the keypad to see if you hear the ipod on any of the sources. If you hear the ipod playing on some sources and not others it obviously means some of your source inputs are having problems and the unit needs to be shipped to Russound for repair.
Make sure the front of the Cav6.6 has the proper colored lights lit up. When no keypads are on the zone should show red, when a keypad is off the color should be green for that zone, if there is a short circuit with the speaker wire the CAV might be in protection mode and the color might show orange.
Hope this helps.
Mar 01, 2009 | Marantz SR-7200 Receiver
How can I take advantage of digital cable?
No digital sound comes from Digital Coax or Optical and in order to utilize a digital signal u need HDMI or Component although component wont be truly digital. Try running everything to the TV then the sound out of the TV into the sound system. If its a high def source like high def cable box then use the optical conection on the back of the aquos and plug than into your surround system. if ur system doesnt support Optical or digital coax then you need an updated surround system. If i misunderstood your question im sorry. If u live in CT though stop by Circuit city in North haven. either myself, Dave, or my associate Justin should be able to help you out. and dont worry we're not on commission or anything.
Dec 17, 2005 | Zenith XBS344 System
Top Russound Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
Gil Shultz
Are you a Russound Audio Player and Recorder Expert? Answer questions, earn points and help others
