Question about Freezers
Fridgedere chest freezer peak and run wattage
  • 884 Answers
What voltage and model? 230v amps at start 5a, run 2a, watts 200w.
120v, or 60hz will be different
Posted on Apr 26, 2014
2 Suggested Answers
  • 124 Answers
SOURCE: freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Posted on Nov 02, 2008
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Magic Chef HMCF7WI is the green light suppose to go off ?
I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
May 17, 2014 | Magic Chef 7 cu. ft. / 198 liter Chest...
Magic Chef #HMCF7W1 should the green light go off?
same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Does it mean any thing if the freezer light is yellow
No. It could be green, red, white, IR, and colored light will work if it's the right wattage and the same bulb barrel, then it will workie...he,he,he,he, awesome colored lights in one freezer---never though of that before, wonderful...GB ya. stewbison
Aug 20, 2011 | Frigidaire 9 cu. ft. / 255 liter Chest...
Why would the top and sides of small chest freezer be warm tot he touch
Some freezers have the refrigeration condenser coils located in the walls of the freezer as opposed to a dedicated coil and fan. This is why you should never drill into a freezer or cooler cabinet to install hinges or make holes for draught equipment.
In order for the door opening to not freeze around the gasket, freezers have a low wattage electrical heater installed and this is probably the heat your feeling on the door.
Hope this answers your question
Nov 21, 2010 | Freezers
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
Feb 01, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
How much energy will the old whirlpool model eah22fw 22ft use
The wattage use of the unit should be on a label plate or sticker. With the age of the unit though, it may not be legible anymore. A dryer does use a lot of electricity. Check the freezer to see if the compressor cycles off. If you keep the door shut, it should. If the compressor stays on continuously, that could use a lot of power.
Jan 03, 2009 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Jul 17, 2008 | Whirlpool 14.8 cu. ft. Chest Freezer...
Chest freezer
Make sure you have power going to the unit. Check the thermostat for power on both sides going in and coming out. You need to give me more info. before I can suggest anything else.
Dec 23, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezers Logo
80 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
