Question about HEWLETT-PACKARD HP G62 Notebook
Failure id ue3rb-5gj72s-xd002k-402g03
Windows not booting getting failure id after test
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
You must install a new windows with real number or get it from someone
Posted on Mar 31, 2014
Hp error
you must get a real number or try some programs they can make a code and you use it afterwords
Mar 31, 2014 | HEWLETT-PACKARD HP G62 Notebook
Media test failure message. Reboot and Select proper boot device
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Rcint failure. string table id not found. '46' at line 246
let me tell what will i do if i m at your place.. i will prepare a windows 7 bootable pendrive first.. then i will forcefully shutdown windows.. then i would turn on pc & i will boot from pendrive and perform a clean install .. i will also format whole harddrive so that problem is uprooted.. try this
Nov 29, 2011 | Computers & Internet
PXE-E61 media test failure on Acer Aspire 5050 laptop
Yes, your analysis of the problem is correct. The problem could be with the hardware & while you are trying to reinstall the Windows OS, the software checks on all hardwares before installing. The best solution would be to take your system to a nearest service provider & get the problem rectified. Once the problem is rectified by them, try to reinstall the OS along with them, so that if there is any other problem apart from the above they will be able to help you.
Feb 08, 2010 | Acer Aspire 5050-3242 Notebook
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
Getting a media test failure on initial boot up then windows blue screen pop up when windows tries to start. Is my video card not working properly? BIOS was reset.
probably hard drive failure.
try changing the boot order in bios.
if that doesnt work try reinstalling windows.
If windows doesn't reinstall then your hard drive is bad.
Oct 06, 2009 | Acer Aspire X1200 AMD Refurbished Desktop...
No sound!
Did you get the driver from HP? Here is a link to install (or download) the driver for your system. It may be beneficial to download it to your computer in case you need it again.
SR1603WM Audio Driver
Dec 22, 2008 | Computers & Internet
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
HEWLETT-PACKARD HP G62 Notebook Logo
20 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
