Question about Refrigerators
Freezer and refrigerator not getting cold but motor running
Both freezer and refrigerator stopped staying cold yesterday. We pulled the refrigerator out away from the wall, unplugged it, and vacuumed out the rear bottom inside near motor of dust and debris. We plugged it back in and the fan is running, but the freezer and refrigerator are still not getting cold after running over-night. How can we fix this problem ourselves?
  • 3 Answers
What is the make and model of your fridge?
Posted on Mar 31, 2014
SOURCE: Frigidaire Refigerator
TEMP FIX i found remove hinge cover top of left door and unplug the Icemaker and fridge will run again havent figured out the problem with icemaker yet though
Posted on Feb 19, 2008
  • 958 Answers
SOURCE: Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
rpbuice
  • 161 Answers
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Posted on Dec 17, 2008
HIRAM517
  • 59 Answers
SOURCE: Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Posted on Aug 19, 2009
  • 132 Answers
SOURCE: FRT221RSH refrigerator warm...freezer cold...some frost
If you remove the entire back panel of the freezer section there is a evaporator (aluminum grill looks like a car radiator, contains r-134a, do not puncture or unit is ruined) Some frost on back freezer wall, means probably this entire grill is encased in frost, not allowing any air flow, which is how the entire refrigerator section is cooled, by air flow) The frost build up has to be removed,(got a hair dryer) you can unplug it for a couple of hours with the door open, overnight is better,this would fix the problem for a couple of weeks....Your automatic defrost is not working, there are three parts- the timer or control board, a heating element, and a bi-metal thermostat(often the problem)
You popped off the cover for the ice maker, you need to defrost the whole freezer section behind the back panel. Freezer cold means your compressor and freon are fine, you have a defrost problem with ice build up restricting air flow. A normal automatic defrost runs every 8 hours, three times a day, rule of thumb.....Sounds like you have a couple of weeks built up...........
hope this helps
Posted on Feb 23, 2011
Won't stay cold
The fridge depends on the freezer for cold. Now that winter is coming, the mice are playing. Pull the cover off the tubes in the back and make sure there are absolutely no openings in the back of the freezer. Mice like to travel up the tubes and chew away at the styrofoam where the tubes go into the freezer. Sometimes, they also get into the freezer and block the drain opening. When this happens, the freezer becomes ice-bound and the cold air won't circulate until the ice and dead mouse are removed. To see the drain, you will have to remove the inside walls in your freezer.
Dec 13, 2012 | Amana Refrigerators
Refrigerator and freezer are not cold
unplug frig pull it away from wall and check for dust buildup on coils and motor . vacum works good.
Apr 29, 2012 | Refrigerators
I have a lg refrigerator . yesterday the refrigerator was warm. the freezer is staying cold
maybe you touch the body of your ref it is only normal it has a heater inside the cabinet wall to avoid mois occrence or to dry. or maybe the defrost heater activate. ok
Feb 03, 2011 | LG LRDN22734 Bottom Freezer Refrigerator
The freezer part of the refrigerator is not freezing well. and the top part of the refrigerator is running at approx 63 degrees
Pull the unit away from the wall and unplug it. Remove the front floor plate and rear panels and then vacuum dust and pet hair away. Look for frost on inner walls of the freezer. If you find any ice, try to remove the inside panel and let the ice melt. I used a air dryer to melt the ice quick with an Amana bottom freezer. vacuum the dust and pet hair at least twice a year.
Jun 13, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerator and freezer are both cool, not cold.
Pull refrigerator away from wall unplug remove lower cover and feel top of compressor. If too hot to keep hand there leave unplugged until start components, compresser windings and condenser fan can be checked. Let me know what you find and I can assist you, Thanks, Sea Breeze
Feb 20, 2010 | GE GSH22JFT Side by Side Refrigerator
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Our fridge isn't staying cold. We have taken off
Sounds like you fan isnt working...its inside the wall..inside take everything out and look for the screws..on the back wall..inside...the fans in there,,unplug and replace..
Sep 20, 2009 | Refrigerators
My pts25lhp is not cold at all in the freezer and the fridge, they are both at 62 deg. I have disconnected the fridge to defrost. What do you think is the cause of this?
Your model will stop running the compressor if the mother board fails. WR55X10942 Main Control Board. Need to pull it away from the wall and unplug and remove the cover over the main control board. Need to examine both sides for burn marks or signs of heat. Be back shortly with photos and what to look for, Thanks, Sea Breeze
Aug 19, 2009 | GE Profile Arctica Stainless Steel Top...
Water inside fridge
the water is coming from the top portion of the refrigerator section. the insulation between the freezer and the refrigerator is getting wet that is why the coldness of the freezer is transferring to the refrigerator trough the insulation foam. you can see droplets of water forming underneath the refrigerator section. sometimes you can see ice forming underneath also.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Refrigerators
GE Side by Side Refrigerator
Check for frost on the back wall of the freezer section. If no frost buildup is noted check that the condenser under the refrigerator behind a removable panel in back is clean and that the fan there operates when the compressor runs.
If you have frost buildup in the freezer section on the back wall you have a defrost system problem. These problems are not related to the cleaning ladies work unless some paper or other item may be stopping the fan from turning.
Jun 11, 2008 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
