Question about HP PhotoSmart Office Equipment & Supplies
Hp printer My hp photosmart c4480 all in one printer is displaying "Print cartridge(s) incorrectly installed" It was working ok and I haven't touched the cartridges, what is the problem. Thanks, Steve
  • 25 Answers
Common problem on this equipement
do try this if you already cleaned head contact on cartridges with no success
INSTRUCTIONS:
1. Simultaneously press both the X button and the power button and hold
2. (NOT simultaneously) press BLUE button then GREEN button then GRAY button (in that order)
3. using blue (or grey) button, scroll-seek to the "information menu" - press OK button
4. press grey button once for "checksum for relock data input" - press OK button
5. press (X) repeatedly until you return to the normal main menu
6. PRINT
Posted on Jan 17, 2015
  • 2692 Answers
SOURCE: My Dell 946 All in One displays 'Right Cartridge Incorrect'
Install old cartriage, if you still have it, let the machine tell you that it is empty, then go through the install process with one of the new ones.
Posted on Dec 19, 2008
rtrahan
  • 741 Answers
SOURCE: Printer reads "Incorrect Print Cardtridge Installed"
According to the HP website, the correct cartridge for the HP PSC950 is HP15 or HP78. Comes in black only or tri-color.
Posted on Dec 25, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
SOURCE: HP PSC 750xi - Incorrect color printer cartridge installed error
I had this same problem and by a luck I fixed it. Not sure if the method to the madness had anything to do with it, but I'll put it down in the order that I did everything. 1. reset to factory defaults 2. pulled all cartridges out. it prompted me to put color in first, then black. message was still blinking so i took out color and put it back in again. 3. i did the partial reset by holding down cancel and left arrow while i unplugged/replugged the printer. 4. no the printer started displaying "remove and check color cartridge" (or something to that degree) 5. i took out color cartridge, cleaned the contacts with water on towel, and replaced cartridge. 6. same message still being displayed, but it allowed me to print a maintenance report. so i then cleaned cartridges and aligned cartridges through standard menu. 7. msg still being displayed, so i turned off/on printer again. this time it came back up with no message at all. 8. printer now works
hope this helps and works for ya'll too!
Posted on Mar 30, 2010
Printer display says "Print cartirdge(s)
when you replaced them did you go into the menu located on the printer and tell the printer that you were changing the cartridges out? If not the printer thinks that you still have not replaced them. To do this all you have to do is go into the menu select the option that says change my cartridges (or something like that) and remove the new ones and put them right back in the printer should then recognize the cartridges.
Jun 30, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
My hp photosmart all in one printer c4480 keeps saying incompatible print cartridge when its the right cartridge and its full of ink and reseting it isnt working. it was working before and now it just...
Hy. I have found a different solution for c4480 "incopatible cartrige". it worked for me so i hope it works for you to
Steps:
1. Press X+power at the same time
2. Press BLUE, GREEN, GRAY
3. press BLUE until you see "INFORMATION MENU"
4. press OK
5. Press Blue until you see "CHECKSUM FOR RELOCK DATA INPUT"
6. OK
7. Press X until you exit all menius
8. When promted for aliement cancel it with X.
It should bypass the error
Dec 14, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Problem inserting cartridges into photosmart c4480; don't snap in
so you removed, but could not insert? ok. google for your printer model on how to insert back. Dont touch the heads on the cartride. try this video link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01370857&lc=en&dlc=en&cc=us&product=3418705
Feb 07, 2010 | HP PSC 1510 All-In-One InkJet Printer
How do I find ink levels for colour and blackHP Photosmart C4480
just go ahead and print atest page
:on computer go to control panel-printer and faxes-ur printer sereis-right click there-scroll down to properties-click on properties-under general tab uw will find print atest page ..there u can find out the ink levels
Jul 04, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP Photosmart c4480 - poor quality photo prints
you shoud test printhead,if they are ok, you choose "best photo" in printer property.
Jun 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
C4480 cannot scan to pc
I can not scan from my printer to my pc. I have a hp c4480. everything works on it. bill
Jan 04, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printer will not print in black
I will try to help but when you installed the printer and the cartridges, did you remove meaning completely remove the tape on the printed circuit and nozzles of the cartridge? Did you remove all the tapes on the machine? It's not likely that the cartridge is defective when it is that new. Hope this helps.
Nov 17, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
41 people viewed this question
Seeker5211
Seeker5211
